Question about Pioneer X-HX5000 Shelf System
CD player displays OC READ
Pioneer XC-HX5000 everything works great, well kept, but CD player no longer functions.  Screen displays OC READ.  Lost the manual. Any suggestions?
  • 190 Answers
SOURCE: hi i have a pioneer
Hello Don,
I wolud recommend you to deal this with a MiniDisc specialist i know. He deals with MDs and has loads of experience helping people on net. His contact details are as follows
David Popovits
Sigma D.O. Electronics
3, Sheinkin str. Tel Aviv, Israel
Tel. 972-3-6290339
Fax. 972-3-6203579
(sigma@netvision.net.il)
As for your E2 at the high track portion of the MD. This is due to very low revolutions of the motor as the laser unit goes to the high part of the disc. If there is an obstacle or even small dirt on the motor it will not revolve, the same can happen if the laser is not "strong" enough or if the recording is made on a cheap or bad disc. The problem is that even if the disc is good and the machine is clean it still can happen and there is not much to do about it. This is the price we pay for those small machines attempting to save power and in the sane time causing us lot of headache.
Thanks for using fixya.. Please rate this solution.. Thank You..
Posted on Jul 12, 2008
tech48
  • 624 Answers
SOURCE: Hello I have a Pioneer XC-L11
It is most likely that the laser pick up is bad. That is the part that reads the disc and is the most common reason. You can try a lens cleaning disc to see if it just needs to be cleaned, but if that does not work you will need to take it in for service. This problem can be caused by several different things, from the spindle motor (spins the disc), to the pick up (reads the disc), or even an IC that controls one of those things. Once you have cleaned the lens, you can also try cleaning the disc's. If a disc has a fingerprint or scratch in the area of the disc that is know as the TOC (table of contents), it will not read the disc. Fingerprints in other areas of the disc will cause the player to skip or even stop playing. I use windex and a soft cloth like a bath towel to clean the disc's, it works as good or better than the disc cleaning kits you can purchase, and it is much cheaper.
If none of this helps, it has a problem that only a trained technician can figure out with the proper test equipment. Then you must decide if it is worth getting fixed. Some service centers offer free estimates, but those are the ones that don't actually check your equipment first before giving an estimate. They just give you a ballpark figure that is usually pretty high. To get an acurate estimate you normally have to pay for it. A technicians time is worth money, my shop charges $25 for an estimate.That is pretty cheap. Some are as high as $65 for an estimate. But if you are paying for an estimate, they will normally at least troubleshoot the unit and determain just what the problem is, compared to a free estimate which is just a guess and a ballpark figure usually high to cover the cost no matter what the problem is. You may also end up paying much more for a repair when you get a free estimate, because you have already approved that amount, and many shops will charge you that much even if they find a simple problem that only takes 30 minutes to fix.
Replacing a pick up normally cost about $125 to $150 because the part can sometimes cost as much as $75.
I hope this was helpful for you and lets you make an informed decision. let me know if you need any more help.
Dave
Posted on Jul 13, 2008
  • 4234 Answers
SOURCE: the display on my old Pioneer stereo multi CD receiver fades
The problem is a bad solder connection probably on the display itself. These are not the easiest to open up. I would not suggest you attempt this if you haven't done these before. This is a simple fix for any shop that handles audio repair. Call around for a shop that works on Pioneer gear and request an estimate over the phone. Indicate that the dispaly has bad connections that need to be resoldered. You may find a shop that will repair this for short money. Where are you located? Perhaps I can suggest a shop.
Dan
Posted on Jan 14, 2009
  • 14 Answers
SOURCE: Auxillary 2 function does not show up on my Pioneer DEH-P2900MP
first thing you do is turn the power off on the radio by hitting the off button . there is a button you have to hold in. it should be the volume knob. if not try some other buttons. you have to hold it in for about 4 seconds. then a menu should come up. if you scroll though and you can turn on and off the aux . if you have any problems let me know
Posted on Jan 24, 2009
SOURCE: Pioneer dvd player will turn on but will not
Will turn on but displays no signal across a blue screen. I did have it working but only in black and white for some reason. I need an owners manuel as well. thanks
Posted on Nov 12, 2009
I HAVE A PIONEER MODEL XV-DV151 AND HAS OC ERROR
while stad by bottan pressing oc error coming on display
Jan 19, 2013 | Pioneer Televison & Video
I need to connect a pioneer amp m-L11 to a pioneer cd player xc L11 - which leads do I need?
It is verry simple to do (Karen) All you need is a (Audio) Patch cord, To connect it up to your amp.
Nov 05, 2012 | Pioneer Audio Players & Recorders
My Pioneer DVD player displays OC ERR 1
You need to replace the IC Amplifiers that is near the channels when you open the player (make sure it is NO LONGER under warranty or else you'll void it). The cause perhaps is that your speakers have been shorted.
Aug 20, 2012 | Pioneer HTZ-161 Theater System
OC ERROR in pioneer dvd player
read the use guide to get correct error and fix it
Apr 25, 2011 | Pioneer AVIC-N2 Car DVD Player
Dsc-363 displays code " oc err 1 "
It's output power amplifier ic problem. change ur output ic
Mar 08, 2009 | Pioneer DV-363 DVD Player
Pioneer CDJ-1000 CD Player jog wheel display
The only way of solving this is to bring it to repair shop and get a replacement screen.
Jan 30, 2009 | Pioneer CDJ-1000 CD Player
No Function Screen or Graphics
you need to check the cable from the brain unit to the display unit. If you need to order a new cable. www,pacparts.com. Login as user with out any input. and look up your model number. probably going to be the rgb cable which looks to be around $80
Jul 12, 2008 | Pioneer AVH-P7480DVD Car DVD Player
Pioneer deh-p840mp
THERE IS A RIBBON CABLE THAT CONNECTS THE FACE PLATES TO THE RADIO THAT NEEDS TO BE REPLACED
May 13, 2008 | Pioneer DEH-P840MP CD Player
Pioneer X-HX5000 Shelf System Logo
104 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
