Question about Logitech QuickCam Connect Webcam
QuickCam Connect Audio test - OK Skype audio test -OK but the sound is intermittent. Your advise? victor victordan33@msn.com
  • 87 Answers
Test the sound offline using your webcam center software. If it isn't intermittent there then its likely being caused by your internet connection.
Posted on Mar 08, 2009
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
Webcam
You both have to be in the same program to use your webcams.
You cannot hear her msn - this is probably a failing on her set up (mic)
She may have a laptop with a built in mic and she needs to nominate her webcam mic as default so that msn/skype software can locate it.
I suggest you both follow these instructions
Audio
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to MSN
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Configure to Skype
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
May 07, 2010 | Logitech Webcam
How do I set-up My Logitech webcam(C500) to use with Skype. My OS is msw-xp. I cannot send or recieve video/sound.
Before you can use your webcam in any chat program you have to configure it to that program
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
Apr 16, 2010 | Logitech QuickCam Connect Webcam
Hi ihave an acer aspire 5600 .My webcam works with other aplications but not on skype and msn.Could you please help me?
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
WINDOWS LIVE MESSENGER ( MSN)
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Feb 09, 2010 | Logitech Quickcam Chat Webcam
Video freezes on Skype with Logitech Quickcam Pro9000 webcam
Normal 0 See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://ca.messenger.yahoo.com/download/ ) set it up as follows:
  1. Click on Messenger at the top left and then go down to Preferences and then the Preference Window will come up.
  2. Next click on Calling and Devices. In the Calling & Devices on the right and set the Microphone and Speakers to the computer Audio Card or sound device installed in the computer.
  3. Just below that, go to the Test Audio section and (in blue writing) click on Open the call setup assistant” and follow the instructions on the left window.
  4. Then after completing the Audio Setup, on left panel, go to down and click on Super Webcam and click on Start Super Webcam Mode Automatically.
  5. Then click APPLY and then OK.
  6. Next click on MESSENGER and then click on MY WEBCAM and you camera should BRODCSAST and you will see your picture.
Hope this helps. Bud
Aug 04, 2009 | Logitech QuickCam® Pro 9000 Personal Web...
Cam doesnt work on msn
Normal 0 See section C. Windows Live Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have there computer setup properly.
A. Skype Setup:
  1. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Mar 20, 2009 | Logitech QuickCam Connect Webcam
Logitech cam microphone cuts out on skype
Normal 0 Normal 0 Go to "TOOLS", click on "OPTIONS," Then go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correctly chosen. Then "make a free test call." Wait till the voice tells you to record. Then when finished talking wait for the test persons voice to insure your audio transmission is working. Then go back to options and test your video settings. Click on Video Settings and proceed to set up you video camera. Also, you can visit this site for additional information to setup video.
http://www.skype.com/help/guides/video/
Jan 28, 2009 | Logitech Quickcam Chat Webcam
Can't hear my sound playback on sound test with skype
After you install Skype and have it operational with you ID . Go to "TOOLS", click on "OPTIONS", nect go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correct Then "make a free test call" .Wait till the voice tells you to record. Then when finished talking waite for the test voice and the test persons voice to insue you audio transmition is work. Then go back to options and test your video.setting. Click on Video Settings and procede to set up you video camera. Also Visit this site to setup video.
Jan 05, 2009 | Logitech Quickcam Chat Webcam
Logitech Quickcam Deluxe not working on my laptop..
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
Dec 26, 2008 | Logitech QuickCam for Notebooks Deluxe
Logitech QuickCam communication with MSN messenger
See C. Windows Live Messenger in the info below.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
NOTE: You audio and video shoud work. Enjoy.
Jun 24, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech QuickCam Connect Webcam Logo
94 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
