Question about Magic Chef CGR3742 Gas Kitchen Range
How to replace temp sensor?
Our oven gives an F3 code, which google tells me is a bad RTD. I took out the two mounting screws, but the wire does not pull forward far enough for me to unplug it. Do I have to pull out the range and remove the back to get to the connector (that will be a serious pain), or is there a trick to fishing the wire further into the oven?
Thanks --
-- Jim
Had to pull out the range. Replacing the sensor fixed it, so dinner was hot, and life is good. -- Jim
Posted on Mar 10, 2009
F3
F3
or
F4Shorted or open oven temperature sensor (RTD)Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Read more:http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Maytag Range / Stove / Oven Fault Codes#ixzz1kNxJMSok
Hope this helps you :)
Jan 24, 2012 | Maytag Ovens
Frigidaire FEF352BADB electric range gives an F3 error code when oven is turned on. The oven temperature sensor apparently is good as it reads about 1050 ohms. What else can I check and how?
F3 - Open oven temperature sensor (RTD)
It suppose to be about 1100 Ohms at the room temperature. If the reading there is wrong, check the sensor resistance at the sensor plug and the wire harness. If there is nothing wrong then replace the control board.
Hope helps.
Jun 14, 2011 | Kitchen Ranges
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Hello my oven will not turn off and it gives me an error of E2 F3
F3
(upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
mode)
Dec 11, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
Jen Air Convection oven keeps giving a F3 error code and F1 error code
F1
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common
problem. Refer to F1 test at the top of this page for more
information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor
(RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
wiring is ok.
Dec 07, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
I get an F3 error code when trying to set the oven temp. Is this problem most likely solved by replacing the temp probe? Many Thanks, Brad
yes F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 24, 2010 | GE Profile JT910SASS Electric Single Oven
Kenmore Model 665 95781000 Stove Displays a EO-F3 code and the oven does not work WHat part work be defective to give me this fault code EO-F3?
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Sep 25, 2009 | Ovens
I have a frigidaire gas oven and stove and am getting an F2 and F3 error code on the display. Can anyone please tell me wht that means?
F2 Oven temperature too hot Check and replace oven temperature sensor (RTD). F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 21, 2009 | Kitchen Ranges
F3 & F1 Errors & oven shuts off
Concerning the F3(Open or shorted oven temperature sensor (RTD)
Concerning the F1(Stuck touch pad)
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Jun 02, 2009 | GE Ovens
F3 code kenmore model# 911-4552090
Hi pickerrauto7,
The f-3 code code indicates a bad or open temperature sensor in the oven. It is the little metal rod in the top of the oven about the size of a pencil.
You will have to remove the back panel of the range to correct the problem. The temp probe is held into place with two 1/4 inch screws. If the connections are good then the probe is bad. Good luck to you on your repair. I am sure this will FixYa. Please dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 30, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Magic Chef CGR3742 Gas Kitchen Range Logo
195 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
