Question about Texas Instruments TI-84 Plus Calculator
HAve to change batteries too often
I need to cahnge batteries every two weeks, without using it much. How do I fix this?
  • 3 Answers
Do you play games normally? This will run down your batteries like crazy! You could also do a search on ticalc.org and find a program which tells you your battery life.
Another idea is to ge more powerful batteries such as Energizer or duracell. Cheap runs will not have as much of a chage.
Hop this fixes our problem!
SJ_Sharks
Posted on Mar 14, 2009
Why my APC BR500c ups makes continuous ticking noise when i switch on after a short break in use ?
Are you getting any warning lights? Your post seems to state that this unit is not very old? If still under warranty contact APC, they have fantastic customer service.
Jun 19, 2015 | APC Computers & Internet
I have Azpen A720 I been having problems with charging my Tablet I had it on charge for an whole week it charge to 52 percent. I got the android from Babcock. I need your help to fix the problem
Failure to charge is due to 1 of 3 problems. The charger, the connector or the battery. Try changing the charger or use your computer's USB port. If that doesn't solve your problem, it can only be a bad connector or the battery. Since both of these are not user replaceable without voiding the warranty, you will need service. Batteries age and wear down. How old is your tablet and is it still under warranty?
Nov 15, 2014 | Tablets & eReaders
How do you change the batteries in BUzz?
The compartment for the battery is located at the back of buzz. You have to unscrew using aa small crew driver to open the lid before cahnging the batterie.
Nov 13, 2010 | Thinkway Toy Story Buzz Lightyear Space...
Hi I have got casio babyg 163 model.i believe it needs battery replacement but cant find the battery model any help plz
mcdevito75 here, Best Bet, look for a small watch repair shop in your area to cahnge the battery as any pressure on the display while changeing the battery on a Casio watch will break it.
Jul 03, 2010 | Casio BG163-4V Wrist Watch
I am using a Dell Laptop and it is inspiron 1501. But its battery is not charging. I get 2 error message the adapter can not recognise... The battery can not recogise.. Something like that. The laptop gets...
try to remove the battery from the computer, after unplugging it, plug in the AC adapter without the battery and check if it will turn on. if it doesnt then 2 possible reason
1. the AC adapter is busted, you can try a known good Dell AC adapter. if its still now working with a know good AC adapter then
2. its the motherboard that needs to be replaced.
Hope this help
May 19, 2010 | Dell Inspiron 1501 Notebook
HALFORDS JUST CAHNGED MY CAR BATTERY AND NOW I AM
here is a link on how to reset your kenwood radio using a universal code from kenwood, it doesn't work everytime, but worth trying. you do need a kenwood remote though..good luck
http://www.ehow.com/how_5164864_reset-kenwood-cd-player-code.html
Aug 12, 2009 | Kenwood KDC-W4534 CD Player
The alernator does not appear to be charging the battery,the car has not been used for three weeks,battery has been charged but battery light stays on,can this problem be fixed easily?
It sound's like the battery need's to be replaced, the alternator can't be checked without the car started, to check the alternator measure the voltage across the battery, it should read higher than the battery voltage. if the voltage on the battery stay's at 12 volt's with the car started the alternator is bad.
Apr 18, 2009 | Ford Escape Cars & Trucks
Kidde alam model 1285 pieping every 2 minutes without any reasons
Check all batteries in the wired and connected detectors, if one of these has a bad battery it will piep . so change it
Dec 21, 2008 | Kidde Nighthawk Combo Gas/co Detector
Cahnging the belts on the fx35
There are 2 seperate belts the a/c and the serp belt. In order to change the belts, there is a special tool that you will need to purchase or rent from Auto Zone. Without this tool you can not replace the belt. Once you get the tool it's one bolt that turns and lets the tension off the pulleys in order to replace the belts. Just did this last week on MY FX35.
Dec 05, 2008 | 2004 Infiniti FX35
Texas Instruments TI-84 Plus Calculator Logo
59 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
