Question about Panasonic Workio DP-3530 Copier
Copy/Printing machine jams
When we send a 2 sided job to the copy machine the paper gets jammed. If we do only single sided it is OK.
Repairman came and cleaned rollers, also there was a sensor in the duplex unit that had come loose.
Posted on Mar 11, 2009
    Scholar:
  • 136 Answers
This tells me your DUPLEXER is the one causing the jam, Ok like when you open the duplexer do you see the paper in their
second does your copier indicae that the duplexer is in stalled ?m print the config page to verify. if it worked ok until this incident then your paper feed tires in your Duplexer is worn and needs to be replaced, do not do this yourself call a Service tech or A dealer to do so, uf your in CT we can help.
Posted on Mar 08, 2009
Kyocera Taskalfa 552ci will not copy single sided. 0800 Jam but will so may other functions...
the service manual says to replace the main pcb before you do this try to upgrade firmware even if it is current or try a different ADF the DIMM could be the problem if the board has 1 try cleaning the contacts with an eraser welcome to Kyocera repair
Mar 07, 2017 | Kyocera Office Equipment & Supplies
When printing color the paper jams. This does not happen when printing black. How do I stop it from jamming when printing color.
Is that true for both print and copy job ?
Where does the jam happen ?
I am thinking if it is at the paper pickup roller area just as the job starts to print and not midway while printing, check the paper quality; dirty pickup roller; clean cork pad and try job from another tray
Sep 21, 2016 | Konica Minolta magicolor 1680MF -...
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Sharp Z-835 Paper Jams
A few things come to mind;
1) Feed rollers in tray are either worn or dirty
2) Transport tires are dirty
3) Fuser worn
If you've had this for 10 years and have not done much to it besides a toner or drum then I would recommend taking it to a qualified technician.
Oct 06, 2009 | Sharp Office Equipment & Supplies
Canon IR1018 forces duplexing
Go to service mode MENU and #, clear all and ok,
after that machine goes to factory sett., reenter your sett. it should work
Jul 08, 2009 | Canon Duplex Automatic Document Feeder
The paper feeder of my canon super g3 jams every time
Yes, there is an easy solution, possibly. Mainly because you say it may do a single job, and then it keeps jamming. Do you see the second sheet jamming in when it is not called for? Anyhow, you may try cleaning the rollers, all of them, like I did here: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html This completely solved my problem of persistent paper jams.
May 04, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
I have a Samsung CLP-510 and I want to print 500 copies of the exact same document, which is 2 pages color. When I do this from MS Word, the printer takes about 25 seconds thinking between each copy. It...
CHeck your settings. If they are ok, then try printing the job from open office or wordpad. Are you using 2 sided printing? I have the same printer and it blazes thru stuff like this printing 2 sided and all. Just have problems with using cheap paper (jams).
Feb 04, 2009 | Office Equipment & Supplies
Panasonic Workio DP-3530 Copier Logo
170 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
