Question about Kenmore 45087 Front Load Washer
Errors F, F11 , F06 - Kenmore 45087 Front Load Washer
  • 1 more comment
  • quicu2009 Mar 18, 2009
    thank you,, opened the washer , found some socks in the draining port, but still with the problem,, lifted the top cover found the one unit with wires (I am not electronic savvy, trying) but I do not know which is the ccu or the mcu,,are together at the same place?
    hi, which one is the ccu and the mcu, only found one panel towards the back of the upper area.
  • quicu2009 Mar 19, 2009
    I am so happy I contact you , I hope I can fix ya the machine...lost a lot of money on coin laundry....and time.
  • 163 Answers
You need to check ccu board and mcu and wiring to both.check to see if any runs are in boards.
Posted on Mar 06, 2009
  • mike cooksey Mar 18, 2009
    one in back is mcu,one behind face of machine is ccu
    good luck and hope i solved your problem.
E03 error code
Error Codes
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
Aug 09, 2010 | Siemens WTXD8300 Electric Dryer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE4T Elite F06 problems
Given I had purchased the Extended Warranty, Sears replaced the washer. So, we will see how this one works.....
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
HE4T F06 ERROR
Wow. Sounds like you've had your hands full with this one. Well, since you've already gone the route of replacing the CCU and MCU, more than likely you have a wiring harness problem and/or drive motor issue (as you have already explained). The following link explains the "F06" error and how to troublehoot:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Review the information and double check to make sure you have overlooked anything. Unless, you have purchased defective replacement parts, I can only assume the motor and wiring. Unplug the washer and perform resistance checks on the motor windings. If you have a multimeter handy, this would be on the RX1 scale. The pin locations are mentioned in the link provided. Each motor winding should read 6 ohms or less. On another note, the vibration problem you mention, was definitely caused by the shocks not being mounted properly. You may consider replacing them, since you said you're still experiencing vibration issues.
If you are still confused by anything, please let me know. I hope this helps you.
Aug 16, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
KENMORE HE4T STARTED AS BALANCE AND F11 NOW ITS F06
ck all the connectors to both boards and motor you may have inadverantly left 1 loose or knocked one off during previous repair
Kenmore 45087 Front Load Washer Logo
105 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
