Question about Fantom Titanium-II (TFD200U2) 200 GB IDE Hard Drive
I connect my external HDD Fantom fine but then I cant see it?
Hello-When I first bounght and connected this external HDD to my Windows XP old PC it connected just fine and I transferred all my files on to it, also the ones in my office computer no problem... but now that I trying to connect it to my new laptop (Windows Vista) it connects fine, it tells me new Hdwe found and ready to use - no problems - but then I cannot see it to transfer data to or from it... I re-connected it to the old PC and I cannot see it there either (in my windows explorer)?
Any ideas?
  • benleves
    benleves May 11, 2010
    can you tell me if your hdd are formatted in fat32 or in ntfs
  • 151 Answers
Right click my computer, select manage, click on disk manager, right click the drive and select import foreign volume.
Posted on Mar 16, 2010
Hi Fixya,We have a desktop pc running windows xp and it does not seem to boot up,the screen stays blank but it does tell us there is no signal to it.I suspect the hard drive has got corrupted somehow.Also...
Hello miriamhyman
Extract the corrupted HDD out of your machine and place it in a external usb box .
Install a new hdd inside your computer . You will have to reinstall Windows XP but you can't find it any more at Microsoft's . Here is a place where you can still buy it :
or buy a Windows 7 install disc ( the box contains two discs , one for 32-bit systems , the other for 64-bit . One of them will surely be compatible with your BIOS ) . Once done , connect your old hdd to the a USB port of your machine . You will be able to retrieve all your files but you will have to reinstall the programs .
Best regards ,
fanaudi .
May 13, 2011 | Packard Bell Computers & Internet
When I plunged in FANTOM firewire and USB external HD (I only use the USB) at windows start it said it wanted to (blue screen) check drive for errors. I agreed and it stopped half way at 41% and did not go...
It is entirely possible that your external hard drive is failing. I would recommend downloading Seatools for Windows (link below) and run extended hard drive test on it. Chances are if it is failing, it still recognizes within the system, but it is not readable enough for windows to display it and allow you to browse.
Nov 12, 2010 | Fantom Drives 120 GB Hard Drive
I have Fantom Drives Titanium 250GB i am not able
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 30, 2010 | Fantom Titanium 250GB External...
Hallo, I have a LaCie Grand 1 TP external harddrive. I cant work in mine hard drive. I cant throw anything away i cant rename documents or put new ones on it. Some background info A few months...
you may face this issue because of differences between mac and windows file systems/partition table and security attributes that may disallow any further changes.
1-try to connect you HDD to a windows Computer and Backup all your files before loses any data(use more newer version of windows like windows 10 build 1709 windows XP is old/out of services and has many problems)
2-after a full backup in windows try to connect your HDD to your mac and format it via your MacBook
3- after formatting your HDD try to reconnect your HDD to windows and copy your files to HDD(windows has a compatible file systems that could read/allow/write mac file systems/partition and its attributes)
best regard
Sep 27, 2017 | LaCie Grand 1 TB USB 20 Hard Drive
System backup
depending on what drive it is. Let's say it's a western digital, They all have software on there websites to copy a drive to a new drive. in westerd digitals case it would be and in the support downloads section you would find the software.
You would have to hook up both drives and tell it which you drive you want to copy from (old drive) and to (new drive)
Mar 04, 2010 | Microsoft Windows XP Home Edition for PC
What should I copy/import from old HDD to rebuild all MS Outlook?
I am not sure whether you are going to have those, any way look for windows and program files, they may contain its settings and more thing if you had concept of "server routing path", then don't worry specify your "routing path" to access the previous one and check it your contacts regarding existence and have fine
Dec 11, 2009 | Microsoft Outlook 2003 for PC
My new portable hdd is not getting detected on my xp
Your USB ports may be version 1.1
You need a USB "Y" cable.
The USB Y cable uses two USB ports on your laptop and the third plugs into the external HDD.
Check RadioShack or maybe the vendor has a USB Y cable.
This will work!
Sep 08, 2009 | Computers & Internet
Hdd connection problem
I bought an ide/sata to usb adapter from Cyberguys for about twenty five bucks. It works ok, but I have to reboot if I want to change hard drives.
Apr 30, 2009 | Computers & Internet
Fantom Drive TFDU16072A Error
2009 06 30 - I just had a similar problem. The Fantom external drive was working fine, but I had to shut down due to a thunderstorm. When I restarted the PC, the drive was not showing up. WHAT I FOUND: First, I didn't find this solution anywhere - everything seemed to point to a new install (or at least how to reformat and start over.) BUT, I right clicked on Computer, Manage, Disk Management - it still didn't show. On the right, under More Actions, I clicked 'rescan disks'. Now it shows up! And all of my data is right there. Whew!
Mar 20, 2007 | MicroNet Technology Titanium (TFDU16072A)...
Fantom Titanium-II (TFD200U2) 200 GB IDE Hard Drive Logo
184 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
