Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Washer arm not working
LG 24"LDS5811ST Dishwasher Bottom wash arm not spinning but top one works fine. No blockage on bottom arm and it's not clogged and spins freely. Could the pump be the problem?
  • 423 Answers
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Posted on Apr 04, 2009
Top wash arm does not rotate, bottom wash arm is fine
When my wife started complaining about her dishwasher not getting the top rackclean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 18, 2010 | Maytag 24 in. MDB8600AW Jetclean II...
Top wash arm does NOT spin, but is not blocked or hard to move by hand. Does this run off water pressure? Whatshould Itry next. I have already removed the filters and cleraned around the pump. The bottom...
Remove the dishwasher from the cabinet and look at the hose going up to the top. Make sure it isn't clogged and that there is nothing in the port where it comes out of the pump. The top arm is powered by water pressure from the pump.
Jun 14, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Bottom sprayer does not clean or work, all items on bottom are the same as put in. Top is fine. runs through whole cycle.2 hr 29 min
Check the free rotation of the spray arm. If arm jets are clogged clean them.
After placing the dishes see to it that, the arm is freely rotating without any obstacles.
May 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LDS5811 top rack not cleaning
I Have the same issue, it sounds like the arms try and start up 4 times then each time power back down, the top arm is not spinning at all. On the fifth time a I hear grinding and then the mid and lower arms spin, soap streaks down the door, nothing stuck in any of the arms, 16 months old, 750.00 out of pocket for junk!
Oct 08, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Top arm doesn't spin
It is important to know that the upscale LG diswashers alternate between washing the top and bottom rack. So it is normal for some arm to not be turning at certain times.
Also, if this dishwasher is set to half load, bottom only, the top arm will never turn.
Oct 16, 2008 | LG LDF8812 Stainless Steel Built-in...
Arms are not spinning
If the spray arms arent clogged up then you have a clogged filter.
Please Rate this !
Jun 23, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Bottom wash arm
there is a blockage but may not be obvious. arm turns only by water spraying out of the angled jets at the end of the arm. take arm off, run water thro the centre hole and this is udually enough to force the debris to the jets. clean out and check
Jul 08, 2007 | Tricity Bendix 18 in. DH090 Free-standing...
Kenmore Ultra Wash Dishwasher
Cyber, did you get down to the chopper screen? If that is clogged with gunk it will restrict the flow and the top arm will not spin. Im going to try to attach a pic of the chopper assy and screen. Catriver..post back
Apr 02, 2007 | Kenmore 24 in. 16582 Built-in Dishwasher
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
533 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
