BEKO HDTV SCREEN PROBLEM
Hi i have got a dark vertical line on right of screen on my lcd hdtv,would have liked to post a picture but cannot on fixya.Hope it can be fixed sadly out of warranty.
  • stewiebee Mar 28, 2009
    Hi many thanks for advise decided to scrap tv will never buy beko again had a fridge freezer lasted 13 months now tv 15 months,beko are total **** cheaply made fit for landfill only.Now bought a samsung 42" plasma.
There is black lines coming up on my becko plasma screen
Posted on Mar 29, 2011
  • 718 Answers
This may be caused by the LCD Controller (TCON) board. Look for the flat cable running from this board to the right side of the LCD. Sometimes the connection needs to be reseated. Have someone knowledgeable in electronics carefully disconnect and reconnect the cable. Test before reassembling the set to verify its solved. You may have to do this several times if other changes show up.
Posted on Mar 06, 2009
Vizio XVT3D650SV 65-Inch Theater 3D Edge Lit Razor LED LCD HDTV has a black vertical 6" wide line on the right side of screen. What is causing this problem? Is it the T-Con board?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 23, 2016 | Vizio Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Vertical lines on tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 19, 2015 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
What causes vertical lines in right half of the screen
Oct 12, 2015 | LG 42LH20 42 in. HDTV LCD TV
42 inch toshiba\r\n tv screen
Dark picture. I adjusted brightness, but it keeps getting dark. It has vertical lines that can be seen in grey areas on the screen.
Dec 08, 2010 | Toshiba Regza 42RV535U 42 in. LCD HDTV
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Darker screen on the right hand side of my Sharp
try going to menu and center the screen both vertically and horizantal, the manual should help
Feb 25, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dark vertical line(s) on Lcd tv
Most likely it's the LCD panel failure. You can replace the panel if you can find a spare part. But the new panel may cost you as much as to buy a new tv. Hope that will help you.
Jan 27, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Dark vertical lines on tv screen
If under warranty then of course use that.
This is a display problem. One solution someone knowledgeable in electronics can try.
This problem can be caused by a bad connection fitting of the flat cables on LCD controller board. Dis-connect the flat cables from the LCD controller(T-CON) and carefully reconnect them. Try the unit before reassembling the back cover. You may have to disconnect/reconnect several times to show improvements if this is the problem.
Sep 25, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Vertical line on KDL-32s20l1
You'll get this abnormality some times due to the signal if you're watching regular analog picture and you have your TV set on full screen, the TV will stretch the picture and you will see more defects than if you're watching it on normal picture. But if you are seeing the same problem when watching HD picture it needs to be serviced try this link I found: http://www.moniserv.com/doc/lcdtv.html
Aug 27, 2007 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
325 people viewed this question
Top Televison & Video Experts
Electro Med Services...
