I have a thumping noise coming from the front end and when I turn right it seems to get louder. Just changed the drivers side hub assembly and the cv joint problem is still there. What could it be?
SOURCE: Humming noise in front end of truck
I'm having the same problem with my 2006 Chevy 2500 duramax...The humming starts at 25mph and then gets less prominent and then at 50mph it gets more prominent and louder, then at 60mph you can hardly hear it.....I did notice a little bit of leakage where the front axel meets the from diff on the drivers side.
Any suggestions?
SOURCE: sharp right turn will produce
a loud pop is either cv axle or ball joint so i would try ball joints or could be a-arm bushings also
SOURCE: thumping noise in chevy tracker 2000model
this noise sounds like your right cv axle. wou might want to have that checked out, they can do great damage if broken while
SOURCE: 2001 Chevrolet Cavalier front End Roar
You must replace wheel bearings in pairs to avoid loading the old bearing and, in time ruining your new bearing hub it is possible that you have already damaged the new hub
SOURCE: Grinding noise front end.
I say it's the CV joints. You have to jack up under the lower A-Arm, to take the spring pressure off of it, to check them.
(Use jack stands, and wheel chocks behind the rear tires. Emergency brake On. Work on a hard level surface. Be SAFE! Trucks can be replaced, YOU cannot!)
