Question about Samsung 61" Slim-Depth DLP HDTV
TV shuts off every few minutes
My 2 year old 60" Samsung DLP television just shuts off. It's very irregular, sometimes after only 5 minutes of use and other times it will play for over an hour before it shuts down. I replaced the lamp but that did not fix the problem. Now Samsung says replace the entire light engine. That will cost over $1,000. I may as well buy a new TV. Do Samsung TVs have to be replaced every 2 years? I feel like a ******. The light engine consits of Ballast, DMD,.Colorwheel, and some fans and switches. Surely there is a way to diagnose which item is bad. Why do I have to replace everything?
The problem lies not with the manufacturer but with the technology. While DLP is one of the clearer, crisper rear projection technologies, it is still rear projection, and therefore the most unreliable of the TV technologies, LCDs being the most reliable and the least expensive to fix (relatively speaking). Projection TVs require that the lamp be changed every 2 years (with about 6 hours a day of use) but this can be as often as 6 months to a year for households that use the TV all day long. Lamps cost 150 to 200 dollars in most cases. Beside the lamp, the other parts in the TV can go as you have learned and they are not cheap to repair. I would recommend an LCD tv as they usually manifest problems in the first year (under warranty) if they are going to have any at all. No man-made technology is 100 percent, but I have to say that Samsung is an excellent brand, very high quality, and more features than the competitors. I own one myself (LCD) and have had it for over a year with not a single problem and it gets heavy use as I use it for HD cable, PC monitor, blu-ray, and Xbox 360.
To wrap things up, let me just say that were this problem to be fixed, being a projection TV you might run into these issues in another couple of years again. I would cut my losses and try an LCD (current generation plasmas are also good but they are super expensive to fix if they do break).
Posted on Mar 11, 2009
Samsung HLS-6167W shuts off every few minutes. I replaced the lamp 3x and recently the lamp ballast and #2 fan. Problem continues, so should I look at the power supply board or the color wheel?
if the sounds a high pitch squeal !! I had an ole tv that did that when u watched it , finally one day the dang power supply up and gave out !! so that must be what the noise was coming from all that time !!!
Dec 20, 2016 | Samsung Televison & Video
What is causing my picture to darken on my samsung 60 inch dlp tv
Most likely the tv projection lamp life are ending.The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours each day?The tv projection lamp life are ending,require a new tv projection lamp.
Jan 04, 2011 | Samsung HL-S6767W DLP TV
My 50” Samsung DLP (model HLN5065W1X) has 2 issues: 1. picture sometimes does not come on When starting up, the warm up lamp is on. Should take less than 30 seconds to come on. Sometimes takes minutes,...
It is a common problem for the Samsung DLP HDTV, the problem is that the color wheel is going to go bad. The only way to fix it is to replace the defective color wheel.
Jun 01, 2017 | Samsung PCJ522R 52" Rear Projection...
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV repair or replace that is the question!
Color wheel sounds like it needs replacement. The set will often shut down when the color wheel gets bad and wont power up.
Jul 10, 2010 | Samsung HLN5065W 50" Rear Projection...
My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
Oct 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
52 HD Samsung tv turns off
I have the same problem with my 56" HD Samsung. It shuts off automatically and then on the power button the word Lamp is light up in green. Sometimes I can turn it back on but other times it won't and I have to wait a bit. It's been embarassing a couple times when people were over for a movie. I believe it might be some kind of overheating problem but would like someone to confirm this.
Jul 06, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P4663W
could be the lamp, and is about time for a new one
http://fixyourdlp.com/blog/?cat=4
Jan 15, 2008 | Samsung DLP HL-P5663W 56" TV
2 year old Samsung 50" DLP
Sounds like a bad digital board to me. Not too hard to replace in those models but, you do have to write down a few settings before replacing it. These settings are available in the service menu. Any questions let me know tvtek@msn.com
Nov 30, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 61" Slim-Depth DLP HDTV Logo
450 people viewed this question
Henry  Thomas
Henry Thomas
