Question about Samsung SCX-4216F All-In-One Laser Printer
Scx-4216 network scan not working
Am using XP
using usb cable.
everything work on the server include print and scan
but client computer only can print. Can't scan
  • Anonymous Mar 14, 2009
    not able to scan
  • Anonymous Apr 13, 2009
    I want a drivwe for scan samsung scx 4216
    futuregroup@mail.com
The solution is using the software smarthur3 that come with the CD, then download smarthur4 on both server and client computer......
smarthur3 will run as network, and use smarthur4 to scan.
on client in smarthur4, under scan , then setting select the network name.
everything work now....
smarthur4 even have pdf format.
let me know if you still have problem.
Posted on Mar 07, 2009
How to add new fax numbar
Posted on Mar 16, 2009
I can't found any scanner driver.....i can print but scann....it's impossible SCX-4300
What OS are you running? I don't see any full-feature software but the Samsung site lists a print driver, a scan driver, a universal print driver and a universal scan driver for Windows 2000 through Win7 x64. Similar drivers are also available for the Mac OSX. I'm not certain of the features in the "unified driver" for Linux. The full-feature software is available for Windows.
To find these drivers, go to http://www.samsung.com/ph/consumer/monitor-peripherals-printer/printer-multifunction/mono-multifunction/SCX-4300/XSS/index.idx?pagetype=prd_detail&tab=support . Click on the Downloads tab and then select Driver. The windows files are all .exe files.
For the SmartThru software go to the above link and select Software instead of Driver. With this software, you will be able to launch a scan from the printer if the monitoring program is running. You should be able to start a scan from the computer with any OS and the Samsung drivers.
Windows XP, Vista and 7 can all acquire scans with Windows software. You can use Paint in all three (File > Import from Camera or Scanner > New Scan). Vista and Win7 add Windows Fax and Scan (New Scan). Vista came with Photogallery and it acquires scans like Paint. (You can download it for XP or Win7.) The Mac also can acquire scans with included software.
One issue that can cause a scanner problem is a bad cable. Scanning requires bidirectional communication with the printer and thus may fail when the printer works. Replace the data cable and make sure to use a direct connection (no USB hub or print server) if you can launch the scan but then it stops.
I hope this helps.
May 15, 2011 | Samsung SCX-4300 Monochrome Laser...
US-4A Keyspan USB Server
if urs is a 3 in one u wil have scan and copy functions also included in this sir.
is urs a 3 in one?
Jun 21, 2008 | Keyspan USB Server US-4A (d47710) Print...
Can i connect Hp F380 all in one printer to Linksys wrt54g, and i am using macbook, help
From looking at the printer information and the router information, you will probably need additional equipment to make this work.
The printer connects to computers using a USB cable. It does not have a network connection, either wired or wireless built in.
That means you need a print server to connect your printer to the network. Some routers have a print server built in, but the WRT54G isn't one of them.
The print server will have some USB ports to connect the printer to, and connect to the router with a cable, or wirelessly.
HP shows this option: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01428401&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&key=null&product=1128296
If you can find that one, it might work the best. Many print servers have a hard time with all-in-one devices. They are usually able to print just fine, but scanning is troublesome. Make sure to review information about any print server you get, or router with built in print server to make sure it does everything you need.
Considering the price of a print server, it might be a better option to get a new printer that has built in network support. They are more likely to work easily and well. But watch carefully to make sure it can do everything you need (print, scan etc) over the network.
May 04, 2011 | Linksys Wireless-G WRT54G Router
Print jobs get stuck in the queue
OK - all the answer posts on HP sites, Experts Exchange and MS have been a joke to this problem so far. HP 10xx series LaserJet printers do not work (well) in a shared environment. I have found two solutions to this problem. If you really don't understand shares/printing/services/firewall exceptions - don't bother trying this - buy a networked printer when the toner runs out of the HP10xx.
If you want to spend a few hours or about $100 for a print server/NAS device, read on... I HAVE an HP1022 shared on a Windows XP Pro SP3 machine serving as a print server to a Vista laptop, a Windows 7 desktop and a Mac-Mini running OS X 10.6.x. ALL are working.
1. Buy a network print server device (or a NAS device with an included print server - I picked up a Buffalo LS-CHL 1TB and it worked out of the box. I AM NOT ENDORSING BUFFALO NAS servers, they get horrible reviews and you may end up having the same problem down the road due to the NAS device) In this case, your print clients (Win7, Vista, XP, MacOS X) can use a traditional SMB Windows client to print or the BETTER solution is to use the print services for Unix client that comes with Windows but is not installed by default. Both clients work, you may have fewer problems down the road using the Unix (LPR) client. See http://www.alexfalkenberg.com/2009/10/06/linkstation-windows-printing-problem-solved/ This is an excellent article on the Buffalo - BUT THE SOLUTION works in a native windows environment as well.
2. Build on the idea from number 1 above and INSTALL the LPDSVC (friendly name TCP/IP print services) on the machine with the printer LOCALLY attached through USB. You will also have to open up some firewall ports on the machine you are using as a print server if you have one running... I used a program exception (C:\WINDOWS\system32\tcpsvcs.exe) but you could lock this down to 1 TCP port if you wish - I think TCP 515 but you'd better check on this one...) Share the printer as normal. Next install the "Print Services for Unix" CLIENT on the machines you want to connect to the printer remotely from. When you connect to the printer share from the clients, select a LOCAL port, create a NEW PORT, select LPR, use the hostname or the IP of your machine acting as a print server and the NAME OF THE SHARE as the queue. (I don't like to have spaces in my share names, so I used HPLaserJet when I set up the share and description.) You will HAVE TO INSTALL THE RIGHT Printer driver locally on each client. This might be easiest just plugging in the printer with a USB cable since the HP printer driver is an installer as well and wants it to be connected locally unless you can extract the driver...)
Sorry I can't give more details than this. If you don't get the jist of what I am saying above. Don't try it. Give up and call the plumber.
Feb 09, 2010 | HP Hewlett Packard LaserJet 1022 Printer
Can't scan via network using Samsung SCX-4725fn
Scan functions are not supported over a network for this model.
Oct 07, 2009 | Samsung SCX-4725FN All-In-One Laser...
Computers not sensing scanner via LAN
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Jun 15, 2009 | HP Officejet Pro L7650 Printer
Samsung scx-4100 scanner error - cannot detect device "Samsung.."
I just fixed this problem for my computer. Try installing the scanner driver. You probably have the printer driver installed but the scanner driver is needed for Smarthru
http://www.samsung.com/us/support/download/supportDown.do?group=&type=&subtype=&model_nm=SCX-4100&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&disp_nm=SCX-4100&model_cd=&menu=download
Jan 05, 2009 | Samsung SCX-4100 All-In-One Laser Printer
HP LaserJet 1018 & DP-G310
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
OR
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Jun 10, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Scx-4521 imaging device driver, scaner
Try changing your usb printer cable with a different brand. I have had lost of machine not wanting to scan because of faulty usb cables, even though you can print it refuses to scan. If this still is not helpful, try downloading the latest drivers from samsungs website.
Mar 21, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Sharing with Samba/Cups
To my best knowledge, you cannot. The drivers and scanning software on your unit are not designed to support network protocols. Your unit does not come with an Ethernet adapter and it is not available as an option. When Samsung fits an equipment with a network card (such as the SCX-4521FN) the drivers and software are enabled for network use. By the way, your toner will only last for 3,000 pages. Are you sure it's a good idea to share such such a small unit over a 10 PC network?
Sep 25, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
495 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
