Question about HP DeskJet 930c InkJet Printer
HP DeskJet 930c is leaking black ink
It's leaking from the right rear corner of the printer. The toner light was flashing and we replaced the ink cartridges (with an HP Cartridge) and the printer still wouldn't print. We noticed the ink leaking when we went to move the printer.
  • Anonymous Mar 30, 2014
    should the cartridge move
    New Friend:
  • 52 Answers
The printer primes and cleans the cartridges when the cartridges go to the right side of carriage. Sounds like a cartridge has either leaked or you have used it enough the the ink pool is full, or you have layed the printer on its side or back. From experence, if ink is leaking out of the printer, your probley better off getting anithe printer. I have tried to take the covers off and clean inside print, and it is a messy job.
Posted on Mar 06, 2009
How can I make my HP 930c print with no color cartridge?
you cannot make it print with no cart, but if you have an old one, drill holes in the top and fill with water, 930c uses weight to establish ink level, after much mucking around I have done this today, printing right now :)
Mar 31, 2011 | HP DeskJet 930c InkJet Printer
Trying to print and an orange light is constantly flashing, checked ink cartridges and paper jams but no problem there
I have had this same thing happen to my 960c! The ink cartridges were new/full (but must have been faulty). I replaced them with different/new ink cartridges, which solved the problem.
Another idea is to uninstall the printer and install it once again.
Oct 03, 2010 | HP DeskJet 930c InkJet Printer
Ink on the bottom of the printer ?
Refill or non-hp ink cartridges have been known to leak ink into the printer.
Aug 07, 2010 | HP DeskJet 930c InkJet Printer
Ink light keeps flashing
reset the printer by turning it off, waiting 10 seconds and turning it back on, also right click on My Computer and select manage..go to services and stop and restart the spooler service
Jul 24, 2009 | HP DeskJet 930c InkJet Printer
Ink light keeps flashing -
Have you made sure that you've taken the plastic strip off of the ink cartridge? I had this problem once and I then realised that i had forgotten to remove the strip covering the ink.
Also, have you installed a colour cartridge? I have the same printer and it wont print unless you have both ink cartridges inserted and in good condition. (If you don't want to fork out for HP Original, I find that the Tesco Remanufactured versions work fine)
Hope this helps.
Joe
Jan 01, 2009 | HP DeskJet 930c InkJet Printer
HP printer using color for printing black text
I have solved this issue on other printers by going to the Control Panel, clicking on Printers and Faxes and right click on the printer icon and select Printing Preferences. Most will have the option in the basic or advanced view to select black ink only, this may also be an option in the Paper/Quality tab.
Oct 18, 2008 | HP DeskJet 930c InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
I am having problems with my deskjet 930C printer. I have just inserted a new black ink cartridge 45A. The light keeps flashing, with the arrow over the colour cartridge smiley. When I replace the new...
Your printer might be having hardware problems. You can try removing and reinserting the printer cable. It might be loose due to the constant movement it does during printing. Also, inspect your cartridge. It is possible you have not removed the plastic covering the nozzle.
Sep 22, 2008 | Computers & Internet
Orange flashing light on printer
No the ink is not to low you could try removing the ink cartridges and using a soft cloth wipe clean the little gold contacts on the cartridge and also the printer. Is the ink cartridge a original one if not even though the HP software states that there is 20% in there the likely thing is that the cartridge is empty replace and this should be OK.
I hope the first suggestion works for you as will not cost any money.
Thanks J
Jan 12, 2008 | HP DeskJet 930c InkJet Printer
Deskjet 930c printer
Good for you for being on the internet and posting the question! The yellow light usually means, paper, ink or a jam. If it's got paper and ink, check for jams and even power cycle it and see if that helps. And try printing, it may just be reporting low ink. Good luck!
Jun 09, 2007 | HP DeskJet 930c InkJet Printer
HP DeskJet 930c InkJet Printer Logo
948 people viewed this question
Ben Johnson
