I have lost the user manual to my laserjet 6l, a sheet of paper has jammed up the machine,and i would like advice on how to clear it, this is the first time this has happened to me, could you please help. thanking you Dave.
  • 101 Answers
Open front cover.
Remove cartridge by handle to yourself.
Take out paper sheet by parallel moving of two hands.
Good luck.
Posted on Mar 06, 2009
How to clear paper jam?
How to clear the jam depends on where the jam is.
If the Jam is in Tray 1:
1. If you can see the jammed sheet, remove the jammed sheet by pulling it straight out.
2. If you cannot see the jammed sheet, open the tray 1 door and pull out tray 2.
3. Push down on two tabs to release the tray 1 panel.
4. Remove the jammed sheet by pulling it straight out.
5. Push up on two tabs to replace the tray 1 panel.
6. Replace tray 2.
If the Jam is in Tray 2:
1. Pull out tray 2 and place it on a flat surface.
2. Remove the jammed sheet by pulling it straight out.
3. Replace tray 2.
4. Press OK to continue printing.
If the Jam is in the Fuser area:
1. Open the rear door.
2. Remove any jammed sheets.
3. Close the rear door.
If the Jam is in the Output Bin:
1. Look for jammed paper in the output bin area.
2. Remove any visible media
3. Open and then close the rear door to clear the message.
It is possible that the paper may tear when clearing the jam. Be sure to clear any paper fragments that tear off.
Dec 16, 2010 | HP LaserJet CP1515n Printer
Paper feed feeds more than 1 sheet at a time
he problem you are having is caused by a worm separation pad assembly. This assembly is what separates the paper into individual sheets. It takes about 30 minutes to disassemble the printer and replace the part. Most printer repair shops will do the repair for you but the cost may be a bit much. If you are interested in doing the repair yourself we do stock the part. We can provide the separation assembly and a service manual on CD that gives directions for replacing the parts plus other information about the printer. The part and guide runs $14.95 plus shipping. Let me know if you need one, tech
Apr 26, 2010 | HP LaserJet 6L Printer
Paper jam in fax how do I clear?
folow the instruction
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
  • Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
  • Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
  • Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
  • Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
  • Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
  • Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
  • Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
    Paper Jam HP LaserJet 1300
    I hope this will be of Help for the HP LaserJet 1300 Paper Jam Trouble Shooting:
    1. See the product user guide for information about clearing jams from the printer.
    2. Make sure that the paper guides are adjusted properly. Slide the guides against the sides of the stack in the main input tray or the priority input tray to center the page. Make sure that the guides are not adjusted too tightly.
    3. The media input tray might be too full. Remove some of the sheets.
    4. Make sure that the media being used meets specifications. Click here to refer to "Media specifications" for more information .
    5. Make sure that the media being used is not wrinkled, folded, or damaged.
    6. Make sure that the printer is clean. See the product user guide for information about cleaning the printer.
    7. If printing to the straight-through output path, close and open the door again to make sure that the green release levers are closed.
    8. The paper might not have been removed from the main input tray before the tray was refilled. Always remove paper form the main input tray before refilling it.
    9. Output capacity might have been exceeded in the paper output bin. Do not allow more than 125 sheets of 20-lb (75 g/m2) bond weight paper to fill the paper output bin (less for heavier paper).
    10. The pickup roller or printer separation pad might be dirty or damaged. Clean or replace the part. (See the product user guide for information about cleaning and replacing the pickup roller and printer separation pad.)
    Apr 03, 2010 | HP LaserJet 1300 Printer
    My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
    Reinstalling the printer is related the Software.
    If the paper gets physically jammed than its the driver setting issue or hardware issue.
    Check if two sheets get jammed or only one sheet.
    If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
    If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
    If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
    If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
    Jul 01, 2009 | HP LaserJet 1010 Printer
    Jam bothed ways
    try this link and scroll down the page and see if anything on the page helps you out... HP LaserJet 6L Printer paper jam both ways Google Search
    Oct 24, 2017 | HP LaserJet 6L Printer
    Paper out jam in hp laserjet 1020
    Please visit this below mentioned link to troubleshoot your printer problem.
    HP LaserJet 1020 Series Printers - Clearing Paper Jams
    Thank You
    Oct 20, 2008 | HP LaserJet 1020 Printer
    Multiple paper feed with 5L
    You need a separation pad kit for your machine. The parts are relatively inexpensive. There are 2 ways to accomplish the fix. You can install a separation pad overlay kit which can be done without disassembly which is simply adding a peice of rubber over the existing pad or a complete roller & pad kit which requires disassembly of the machine. The easiest is the overlay however best and longest fix is the full kit replacement. Here's a link to each of the kits off of ebay.
    Overlay Kit: (5 minute install) Approx. $10.00
    http://cgi.ebay.com/HP-Laserjet-5L-6L-3100-3150-Jam-Repair-Kit-Feed-Fix_W0QQitemZ230300272758QQcmdZViewItem?hash=item230300272758&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
    Full Feed Replacement Kit: (30 minute disassembly required) Approx. $25.00
    http://cgi.ebay.com/HP-LASERJET-5L-6L-3100-FEED-JAM-REPAIR-KIT-VIDEO-8-PCS_W0QQitemZ120319146203QQcmdZViewItem?hash=item120319146203&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
    Here's a link to a fre service manual for the machine just in case you get into difficulties:
    http://www.feedroller.com/Store/Service%20Manual/LASERJET%205L,%206L,%206L%20Gold,%206L%20Pro%20Service%20Manual.pdf
    Hope that helps you. If so please rate me with a FIXYA!
    Oct 19, 2008 | HP Office Equipment & Supplies
    46 people viewed this question
    jasbo
    jasbo
