Question about LG 42LG70 42 in. LCD HDTV
Picture goes off within seconds once turned on
I've been having this problem for a while now. Sometimes I will turn on the tV and the led comes on red then it changes to blue and all the picture disappears. The only solution is to turn it off and back on again.
Sometimes I get no picture but get audio.
  • 718 Answers
You will have to do some detective work here. If you are getting audio but no video then
the next time this happens take a strong flashlight and hold it against the LCD screen.
Look closely around the edge of the flashlight and see if you can see an image.
If you see an image then the problem will probably be in the inverter board or the power supply board to it.
Posted on Mar 06, 2009
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
Samsung led tv troubleshooting guide
i have 65 inch samsung tv LED UA65D8000XN if you plag in red light on if you tuch power ON was blinking then the blinking it will stop but the tv will not turn ON the tv no display no picture relay click about once per second but the tv will not turn on thanks for any solution
Aug 22, 2012 | Televison & Video
Sony kv 27V15: No picture but sound
Hi! the trouble indicates that your television's picture is the culprit, have your unit check by a qualified technician for verification.
Sep 12, 2009 | Sony KV-27V15 27" TV
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
No Picture no sound on a Hitachi Rear Projection
if the 120v never comes up, check e994 as it is probably open, and either the blue horizontal retrace cap infront of the h-out transistor is burnt/shorted or transistor could be.
Aug 04, 2007 | Hitachi 55FX48B 55" Rear Projection...
LG 42LG70 42 in. LCD HDTV Logo
220 people viewed this question
Computer Repairing
Computer Repairing
