Question about Frigidaire FEF366 Electric Kitchen Range
F1 flashes on range modelfefl77ase
Fefl77ase range model oven will not shut off and flashes f1 onclock panel
  • 15,935 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
$%$ERF
Posted on Oct 01, 2010
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Oven will not shut off.Also f1 flashing on display
Hi
Thanks for using FixYa. Error F1 in your Frigidaire Electric Range means that the control panel has gone bad and to resolve this issue it should be replaced. Unfortunately there is no other way it can be resolved. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 24, 2010 | Frigidaire FEF366 Electric Kitchen Range
Electronic panel malfunction
A F1 code on Jenn Air refers to a failure in the ERC (electronic range control). There is not a fix for it other than replace the control.
It looks like the part is still around if your model starts with JGR8850 that is. The price of the part is around $300.00 so.... not sure if it would be worth putting that into this, your call
May 08, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Our Fridigaire range oven will not shut off. In
F1 is a bad oven control. (clock).
It must be replaced.
Unplug the range.
Remove the screws from the rear panel.
Remove the wires from the (clock).
Replace the EOC (clock) with a new control and bake me some cookies.
Feb 02, 2010 | Frigidaire Ovens
I have a Frigidaire Electric range Model FW647W-7 Type 351. It began to show an F1 error on the panel. I reset the power circuit breaker and the panel is no longer powered until I turn on an element...
This is the main control board there talking about. The repairclinic.com will have it. Here is the one I think it is...
http://www.repairclinic.com/SSPartDetail.aspx?s=t-FW647W-7-%3d%3db2a13c212i1056306&PartID=1056306
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Sep 26, 2009 | Kitchen Ranges
OVEN SHUTTING OFF, CLOCK FLASHING
ve continually had the same problem for years. Now the display flashes F1 and beeps continually and I have to keep the unit unplugged. I can use the burners and manually light them but the oven is unavailable because there's no power.
Mar 29, 2009 | Tappan TGF657 Gas Kitchen Range
I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
Mar 19, 2009 | Maytag MES5570 Electric Kitchen Range
F1 flashes on range
@$#%$TRG
Mar 06, 2009 | Frigidaire FEF366 Electric Kitchen Range
Maytag MER5770AAW Oven
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Apr 08, 2008 | Maytag MER5770 Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
158 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
