Question about Hoover AAA160 Front Load Washer
Hoover Electra 540 Dual Spin. Are hoses still available for this model? I require the hose from the filler to the drum and also from the drum to the pump.
    President:
  • 1,294 Answers
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
You can give them the diametre (inner/outer), length, you can of course get it, substitutes, at your local shop also.
Posted on Mar 21, 2009
My Hoover BOSS 2315l started having issues not finishing the spin cycle, now it just continues to turn off every few min, so I need to keep restarting it. Does anyone know whats wrong please.
Symptomatic of a blocked drain pipe, blocked filter, or a failed drain pump, drain pump with a broken impeller.
Remove the filter cover and check for obstructions. Attach a hose pipe to the drain hose, wrap it with a towel, hold the two hoses over a bucket and get someone to turn the hose on until you can't hold the pipes any longer, usually about 15 seconds. This clears obstructions in the pipe into the machine drum and filter. After checking the filter and behind it, put it on for a rinse and spin.
If the pump has failed, you can drain the machine by lowering the drain hose into a bucket or floor drain.
There are videos online on how to change out a faulty drain pump.
Jan 22, 2018 | Hoover Washing Machines
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Please help me I don't know how to put ll the
more info needed like how many pipes. however you should have 3 pipes . 1 red , 1 blue and 1 other .
the red connects to your hot water supply
the blue connects to your cold water supply
and the other pipe should come from the bottom of the machine and is your waste which will need to be connected to the sink waste or another waste pipe.you must ensure the waste pipe is fitted otherwise when you run the machine it will empty on to the floor
Oct 02, 2012 | Washing Machines
My Hoover Front loader is leaking water from underneath the machine. It is NOT the taps..I believe it could be the rubber seal just inside the door of the machine, as it has a hole in it. Could this be the...
If the hole goes right through the seal it could be the cause, but I am inclined to think it is a vent hole for the seal and that a leaking seal will come out on the front panel. Remove the machine back and check the pump seals and the hoses, it is more likely those at that age. Take care, there may be live terminals and connectors inside the back of the machine when the power is on.
Mar 27, 2011 | Hoover Washing Machines
My Hoover 750 washing machine does not spin any more. What would cause that and can I fix it with a new part?
Hello.
The answer to your question is YES.
And below is the instruction on how to solve the problem.
The Hoover750 is a washing machine that offers many standard features and a few additional options, including energy saving cycles, variable spin and water pressure options and pre-wash, extra rinse and timer features. Available online and in select appliance, department or home retail stores, the Hoover washing machine should function well with basic maintenance and care. However, if individuals experience problems with the machine, some troubleshooting steps may be beneficial in locating the source of the issue and a potential resolution.
1. Ensure the Hoover washing machine is firmly connected to a grounded power supply if the machine is not working. Reset the circuit breaker if necessary.
2 Turn the main power switch to "On" and open and close the washer door firmly if the electrical outlet has power but the washer is not functioning. The washer will not operate if not turned on or if the door is open.
3 Verify the water inlet hoses are connected firmly and are turned on if there is no water flowing to the washing machine. Straighten out any kinks in the hoses and remove possible obstructions from the inlet screen.
4 Straighten the drain hose if the water is not draining from the unit. Remove any possible blockages from the drain hose. Tighten the hose if necessary.
5 Avoid selecting a "No Spin" option if the washer is not spinning water out of the drum. Choose a new spin cycle and press "Start" to remove water from the drum.
6 Verify that all four feet are touching the ground evenly if the washing machine is rocking or vibrating during use. Adjust as needed.
Thanks.
Feb 19, 2011 | Hoover Washing Machines
I have a Hoover washing machine, its a front loader, I don't have the exact model in front me at the moment. I recently moved house, and yesterday after re-plumbing my washing machine, I put the washing...
If water remains in the drum after the drain cycle, the unit will not go into the spin cycle. There may be a couple of reasons for your problem.
Make sure the drain hose is raised above the machine hose outlet to create a siphon effect. The drain hose needs to have a loop in it to work correctly. You can tie a string around the hose and hook it on the water valve creating a loop in the hose. Raise the loop of the drain hose so the top of the loop height is at the center of the washer drum.
Apr 06, 2010 | Hoover AI130 Front Load Washer
Drum not turning
Problem sorted, motor is brushless and tested ok. Traced problem to statup capacitor, no circuit across terminals, will be relatively cheap fix
Jan 21, 2009 | Hoover AAA160 Front Load Washer
Hoover Electra 540 Dual Spin Washing Machine top left drawer
Hoover Electra 540 This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2008 | Washing Machines
Hoover AAA160 Front Load Washer Logo
269 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
