Question about Kenmore Elite HE3 Steam 8674 Dryer
My clothes are very damp after 2 hours of drying
The Dryer heats up but not to the degree that it used to.
I have notice water in the aluminum exhaust line.
  • 38 Answers
Check for lint buildup in the blower fan assembly.
check for blockage in the exhaust tube
check the exhaust flap on the side of the house to make sure it is opening properly
as far as the water in the line .....it may be moisture from the outside leaking in or a lint blockage soaked with moisture (although that is rare)
Posted on Mar 20, 2009
Clothes do not dry and stay damp even after 2 hours of running the dryer
Lots of possible causes. Verify the dryer exhaust vent is not plugged or full of lint, verify dryer is receiving the correct voltage. Verify the heat setting on the dryer is not set to off very low. If none of the above items fixes the problem, you most likely have an issue with an internal part of the dryer, such as circulation fan, heating element, controls.
Oct 02, 2011 | Dryers
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
Dryer doesn't get hot enough to dry clothes
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this I fine then you’ll need to check the thermostat, igniter and coils. Also as its only 3 months old so it is recommended to use the warranty to avoid any further issues. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Samsung 7.3 Cu. Ft. 7-Cycle Gas Dryer -...
Dryer wont dry, clothes are just as damp as they were at the beginning
Is the dryer heating? If not check heat system for part failure. If it is heating but taking too long to dry check for plugged exhaust. Best way to check exhaust is to disconnect exhaust from back of dryer and dry a load.
Mar 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
My dryer take longer and longer to dry clothes. I
check to make sure lint trap is clean also make sure exhaust is not clogged. if both are clear than you probably need to replace your heating elements. if this the case than you need to call an appliance repair tech. trying to do it yourself could result in electricution. also make sure your drum is turning.
Aug 18, 2009 | Bosch Axxis WTA4400 Dryers
Will not dry clothes and trickels water down the front!
Check to see that the lint filter and exhaust duct are clear all the way to the outlet. If the moist hot air is not being exhausted the clothes will not dry. The water you saw may be from condensation of the moist air that is not being vented out.
Aug 12, 2009 | Dryers
Maytag performa intellidry dryer model#PYE4500AYW
Check drive belts. If too loose or too worn it will not spin at proper speed.
Mar 27, 2009 | Dryers
Our LG dryer doesn't get completely hot until the clothes are mostly dry.
heated air enters the dryer at 140 degrees farenheit,
a portion of the heat energy raises the temperature of the water in the clothes.
When the clothes are cold and wet, the difference is large transfer is rapid
a lot of heat transfers to clothes and the exhaust air is damper and colder
As the clothes get warmer and dryer, proprtionally less heat is extracted from the incoming air, and the exhaust air is warmer and dryer.
When the clothes are dry, and at 140 degrees, the same temperature as the incoming air. no heat is removed from the incoming air
the dryer should then stop heating, draw unheated air through the drum and clothes to cool, and reduce wrinkling
then switch off
the dryer appears to be operating correctly
Oct 31, 2008 | Dryers
Tumble dry is heating but takes forever to dry
check your air exhaust (including the lint filter) from the air duct connector (remove duct if necessary) on back of dryer to the exterior of the building. Somewhere, there must be air blockage.
Jun 17, 2007 | Creda IWD12 Front Load Washer / Dryer
Kenmore Elite HE3 Steam 8674 Dryer Logo
131 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
