Question about LG WM1814CW Front Load Washer
I have an error message on my LG WM1814CW washer The message
The message reads OE What do I do?
  • 283 Answers
This means the machine did not drain within a 10 minute time period. check the pump trap for debris and clean out. Check the drian hose. Check for drain pump operation diring drain period
Posted on Mar 06, 2009
Wm1814cw will not drain oe error
oe on your machine means your pump is not emptying empty the machine manually and clean out your pump it should work then
May 23, 2013 | LG WM1814CW Front Load Washer
Error message oe. and will not spin.
Actually, that is not oe, it is DE, which stands for Drain Error. Check the filter behind the access door on the lower left front of the washer. You should be able to drain the water out using the small hose there first before opening the filter. If there is nothing in the filter, you will have to replace the drain pump motor.
Feb 12, 2011 | LG WM1814CW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Jul 06, 2009 | LG WM1814CW Front Load Washer
The OE Message on my LG Tromm WM1814CW
Open the little trap door on bottom front of unit. Unscrew lint filter trap. Drain water first with small tube.
Sep 08, 2017 | LG WM1814CW Front Load Washer
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
LG wm1814cw washer
No, there is no access to the drain pump other than by removing the front panel to get to it.  It is a job that can be done but you will need to spend some time to disassemble the machine to get to it.
Sep 04, 2008 | LG WM1812C Front Load Washer
Lg wm1814cw drain error
Click on LG (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Nov 28, 2007 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer Logo
215 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
