2001 silverado (Thanks Banker099)
Try this link for page below
This image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.
Powertrain Control Module (PCM) C1 (BLU)
Connector Part Information
• PCM Connector C1 Assembly 12191489
• TPA (BLU) 12176408
• Connector Cover 12191108
Pin
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
LT GRN
1867
12 Volt Reference
PNK/BLK
1746
Fuel Injector 3 Control
LT GRN/BLK
1745
Fuel Injector 2 Control
5-10
Not Used
11
LT BLU
1876
Knock Sensor 2 Signal
12
DK BLU/WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
Requested Torque Signal
14
ORN/BLK
1061
UART Serial Data [Secondary]
15
DRK BLU/WHT
774
UART Serial Data [Tertiary]
16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
440
Battery Positive Voltage
21
YEL
1868
Low Reference
22
Not Used
23
PPL
719
Low Reference
24
Not Used
25
TAN
1671
HO2S Low Signal [- Bank 2 Sensor 1]
25
TAN
413
HO2S Low Reference (Denso Sensors) HO2S Low Signal (Delphi Sensors)
26
TAN
1667
HO2S Low Signal [- Bank 2 Sensor 2]
26
TAN
413
27
Not Used
28
TAN/WHT
1669
HO2S Low Signal [- Bank 1 Sensor 2]
28
TAN
413
29
TAN/WHT
1653
HO2S Low Signal [- Bank 1 Sensor 1]
29
TAN
413
30
LT GRN
1478
Coolant Level Switch Signal
31
Not Used
32
BLK/WHT
771
Transmission Range Switch Signal A
33
PPL
420
TCC Brake Switch Signal
34
WHT
776
Transmission Range Switch Signal P
35
GRA
48
CPP Switch Signal
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38
PNK/WHT
1101
Damping Lift/Dive Signal
39
Not Used
40
BLK/WHT
451
Ground
41
BLK
407
Low Reference
41
GRA
720
Low Reference (w/o Delphi HO2S)
42
Not Used
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRA
474
5 Volt Reference (FTP Sensor)
46
GRY
474
5 Volt Reference (TPS Sensor)
47
GRY
597
5 Volt Reference (MAP Sensor)
48
GRA
596
5 Volt Reference (EGR Sensor)
49 50
Not Used
51
DK BLU
496
KS [1] Signal
52
Not Used
53
BLK
470
Low Reference
54
BLK
452
Low Reference
55
BRN
1456
EGR Valve Position Signal
56
Not Used
57
ORN
440
58
DK GRN
1049
ECM/PCM/VCM Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
469
Low Reference
61
PNK/BLK
632
Low Reference
62
Not Used
63
GRA
720
Low Reference
63
TAN
413
64
Not Used
65
PPL
1670
HO2S High Signal [- Bank 2 Sensor 2]
66
PPL
1666
HO2S High Signal [- Bank 2 Sensor 1]
67
Not Used
68
PPL/WHT
1668
HO2S High Signal [- Bank 1 Sensor 2]
69
PPL/WHT
1665
HO2S High Signal [- Bank 1 Sensor 1]
70
BRN
1174
Oil Level Switch Signal
71
Not Used
72
YEL
772
Transmission Range Switch Signal B
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
Off/Run/Crank Voltage
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/WHT
878
Fuel Injector 8 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Valve Control
80
ORN/BLK
510
Low Reference
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
