Question about Dishwashers
FRIGIDAIRE GALLERY 4000 DISHWASHER MODEL NUMBER: GLD4355RFB1 IN THE MIDDLE OF CLEANING CYCLE...A "ER" CODE IS DIDPLAYED AND LED LIGHTS BLINKING ON THE TOUCH PAD. I PURCHASE IT 1/2008.
  • michael_shee Mar 12, 2009
    THANKS FOR THE HELP.I HAVE ALL READY TRIED TURNING OFF THE BREAKER BEFORE I CONTACTED YOU...BUT IT DID NOT RESET. I WILL TRY TO CALL THE MANUFACTURE SINCE IT IS ONLY 14 MONTHS OLD
    AND SEE WHAT CAN BE DONE. AT LEAST YOU POINTED ME IN THE RIGHT DIRECTION.
    MIKE.
  • 19,396 Answers
Try first unplugging power and see if this reset the appliance.
Posted on Mar 06, 2009
  • Ginko
    Ginko Mar 06, 2009
    Try first cutting power, either by unplugging power cord, or by tripping circuit breaker.
    If the fault does not clear, you ,ay have a faulty control board, defective heating element, faulty MCU, or valve or pump, depending on what code you gen and on what part of the cycle you get the code.
    If the machine had been purchased 1/08, it may still be under warranty, as many faults are covered for over one year.
    I suggest ringing the manufacturer by calling the phone number listed on the owner manual, and asking them if the repair can still be covered, at least partially (part price).
Frigidaire FFBD2406NW0A then clean wash drying and 4 hour led lights are blinking
I appreciate your post, friend!
I understand that the clean, wash, and dry buttons on your Frigidaire dishwasher are blinking along with the four LED light. This appears to be a delay start cycle. I would recommend pressing the cancel button. If that does not clear the lights you can perform a reset and to do that you would need to disconnect power from the dishwasher for roughly ten minutes. I hope this is helpful. -Matt
Feb 20, 2015 | Frigidaire Dishwashers
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
I get an Er code 5 on our Dishwasher and it keep restarting in the rinse mode
Thank you for your post, friend!
I see you are having trouble with your Frigidaire dishwasher and you are receiving error code "5". However, it appears "5" is an invalid error code. May I have you model number please? Typically you can locate your serial tag on the inside wall on the left hand side. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your dishwasher. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 18, 2014 | Frigidaire Dishwashers
I have a Frigidaire model#PLD4555RFCO the er code and the washing and drying and clean and S lights are on and blinking on the display. have any ideas what the problem is?
Hi
"Er Clean S" is a common error with Frigidaire which means shorted keypad. The issue is with the touchpad/keypad that should be replaced. However, before replacing the keypad you can unplug it and take it apart completely and use a hair dryer to blow some warm air on the keypad assembly to blow the moisture off. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Frigidaire Professional Series 24 in....
4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire 4000 series dishwasher error code
This is likely an indication of a problem with the circulation pump motor under the dishwasher like maybe a bad circulation pump motor but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire gallery series FDB125ORES1 wash light blinking, dishwasher won't cycle on.
The lights flashed on mine for about three months before smoke started to pour out of it during the drying cycle. It nearly burned my house down.
Aug 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
81 people viewed this question
Top Dishwashers Experts
