Question about Mitsubishi WS-65513 65" Rear Projection HDTV
It is your TV problem and there would be few capacitors in power supply and deflection section that are weak and should be replaced for correct picture.
Posted on Mar 06, 2009
If you are comfortable with electronics repair, have electronics knowledge, soldering tools then check weak and leaky capacitors in TV and replace them. This will resolve TV problem.
Check electrolytic capacitors in Power Supply and Horizontal Deflection area on main board.
you will notice few caps plastic jacket (cover) is bit shrinked, replace them with same value.
It looks like you have a convergence problem here, probably a defective convergence IC.
Do the steps below:
To start unplug TV from power for ten minutes.
Try unplugging the video cable, test the TV with a different receiver box and also with a different cable if possible, this will tell you if problem is TV.
If the problem is the TV, then if you have wavy picture, with colors blurred and not matching, or distorted picture at the screen side, then that means that one of the convergence ICs had blown.
Replacing the convergence ICs is a delicate job, and must be done by a technician.
Link below shows the replacement procedure on a different rear projection, procedure is very similar on your TV:
Fixing Convergence problems in RPTV's
May 12, 2014 | Vizio L37 Television
Oct 10, 2010 | RCA P52926 52" Rear Projection Television
Dec 14, 2009 | Televison & Video
Mar 24, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Jan 28, 2008 | Samsung DynaFlat TX-P2775H 27" TV
Sep 20, 2007 | Toshiba 57H82 57" Rear Projection...
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Aug 22, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Feb 28, 2007 | Toshiba 50H72 50" Rear Projection...
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
Jun 17, 2014 | Mitsubishi WS-65513 65" Rear Projection...
289 people viewed this question
Is this the solution?????? What capacitors? Where are they? Did I pay for this one line answer?????????????
