Question about Hobart H600 Stand Mixer
Hobart H-600-T Mixer Shuts down while mixing bread dough
This is a very old mixer that when mixing bread dough for a while ,it shuts off until somethng electrical cools down and it works again until it shuts down again. I replaced the heater relays on the side of the motor starter, still shuts down when something electrical heats up.
Mod # H600 T
  • 6 more comments
  • Anonymous Mar 08, 2009
    Hey & thanks for the replay , Yes I replaced the heaters # is 42010. the ones I replaced looked okay. there mounted on the side of the old arrow hart motor starter.
    The mixer cuts off when mixing bread dough - (for serving rolls)
  • bigb0030 Mar 16, 2009
    I figured it out ,thanks anywho.
  • sales443 Mar 19, 2009
  • rennieg Apr 14, 2009
    Hobart Mixer will not operate in the gear #1 position under load
    mixing pizza dough. It will mix #2 position for a short period of time
    and then it starts to cut out. When under load on #1 the mixer will
    trip the breaker in the panel.
  • spovk Apr 24, 2009
    when put under load, shuts down after 10-15 min.
    mixer shuts down
  • jamespae4 May 05, 2009
    how do I fix the contact overload? and what is this contact overload? any pictures for me to look at?
  • 640 Answers
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Posted on Mar 07, 2009
  • mmaddkanik Feb 14, 2011
    I have the factory manual,but it does not!have a wiring schematic!220 volts,50 cycle,where! Montego bay janaica mmaddkanik@yahoo.com.
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
My mixer just started smoking while i was mix some
Your mixer may still be good, let it cool down and then check it out, If it runs OK then there is no problem. The motor in your mixer probably over heated from trying to mix bread dough which will make any mixer work hard. These mixers will get warm when over worked but unless heavy smoke was coming out and you were getting a burning enamel smell it is probably OK. Let it cool and try it but I suggest you not use it for bread any more.
Oct 08, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Jun 07, 2009 | KitchenAid K45SS Classic Stand Mixer
Hobart A-200 mixer (OLD!) runs hot & shuts down.
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
May 25, 2009 | Hobart A200 Stand Mixer
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Mar 28, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Contact overload for h600 3 phase mixer
I'm a hobar tech and repair these often.The problem is the overload contacts are opening so the motor doesnt burn up.I know the mixer is old and the overload has weakend over time or simply the mixer is being overloaded with too much product.Did you just get this mixer?change the recipe?mixing pizza dough and adding ice?Any new employees if it's in a buisness?
Mar 19, 2009 | Hobart H600 Stand Mixer
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
Hobart H600 Stand Mixer Logo
1,355 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
