Question about Yahoo Mail
My yamaha dragstar 650 is too quiet
I have just purchased a 1999 dragstar 650. it is a minter with brand new remus exhausts. i love the look of the pipes but cant help thinking that they are far too quiet compared to my friends bikes. i believe that there is something that i can do to the baffles and have been told that they are " turnable" or even "removable" is this true? if so how is it done please?
  • 93 Answers
Usually the exhaust pipe has a couple of rivets at the side facing the wheel remove those, and the muffler comes out easily
Posted on Sep 10, 2009
1999 Yamaha XVS 650 Dragstar immobilizer problem
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
https://yamahaclub.com/forums/topic/12681-immobiliser
YAMAHA XVS950A Owner Manual Page 22
Yamaha XVS650 Service Manual
OEM parts for Yamaha
YAMAHA XVS650 Owner Manual
Jun 02, 2013 | 1999 Yamaha XVS 650 Dragstar
2007 Yamaha XVS 650 Dragstar Classic oil pressure switch
2007 Yamaha XVS 650 Dragstar Classic oil pressure switch Google Search
http://www.starbikeforums.com/forums/49-v-star/5058-now-my-low-oil-light-comes.html
May 05, 2013 | 2007 Yamaha XVS 650 Dragstar Classic
1999 650 Yamaha Dragstar classic paint code
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha Motorcycle Paint ColorRite
Find the color code of your Yamaha Motorcycle
Nov 16, 2012 | 2000 Yamaha XVS 650 Dragstar Classic
1999 Yamaha XVS 650 Dragstar backfires
Hi, Thomas and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Exhaust popping backfire Yamaha Star Forum
https://yamahaclub.com/forums/topic/21967-2005-vstar-650-backfiring-new-rider
Aug 24, 2012 | 1999 Yamaha XVS 650 Dragstar
Hi i have purchased a yamaha xvs 650 vstar classic 2003 model fitted with BUB exhaust pipes and i am getting poping and back fireing when decellarating and have been told the carby may need rejetting,could...
If the mechanic did not replace the exhaust pipe gaskets in the head or on any connections between the head pipes and the mufflers , the air leaks could be igniting unburned fuel in the exhaust , causing the popping and back firing. Try replacing any gaskets in the exhaust system.
If you have a flat spot or hesitation when accelerating than you probably also need to rejet the carburetors. Bigger main jets should fix that condition. A jet kit may also contain differently tapered needles for the slides to help compensate for the change in the acceleration curve.
Jan 24, 2011 | 2003 Yamaha XVS 650 Dragstar Classic
Is it neccessary to restrict 650 dragstar to 25kw
Orig power is 40 HP (29.2Kw) If that is required, it can be done by restricting top speed, exhaust pipe and/or chokeing the carb abilities but will take the fun out of riding big bikes..
Mar 22, 2010 | 1998 Yamaha XVS 650 Dragstar
How do you remove exhausts from yamaha dragstar 650 classic
If you follow the pipes they will tell you by themselves they're really easy you have four alan bolts at the blocks 2 and 2 then be careful to dislodge the pipes from the balancer then there are a couple of bolts behind the wide parts.
Oct 15, 2009 | 1999 Yamaha XVS 650 Dragstar Classic
Bars not aligned
you can loosen a bit any mounting bolts holding the bars, then use a bit of force to pry it to where you want them, then re tighten the bolts
Jul 22, 2009 | 1999 Yamaha XVS 650 Dragstar Classic
1999 yamaha dragstar paint
Go to a local FinishMaster store and they will use a color eye to find u a color
Jul 17, 2009 | 1999 Yamaha XVS 650 Dragstar Classic
Yahoo Mail Logo
185 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Barbat Nae
Barbat Nae
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
