I purchased a Samsung DVD-VR375 Combo DVD Recorder & VCR last year. I am in the process of moving and am trying to install it to my toshiba tv. I can not find my owners manual. I am sure it is in a closet somewhere, but can not put my fingers on it yet. Anyway I can get a copy of the owners manual? I bought it at Best Buy with my stimulus check. Thanks in advance for your help. Patti Anne Blake 111 Oxford Ave Portsmouth, NH 03801 PABlake@gimail.af.mil
  • 10,594 Answers
Click Samsung Support and download user manual of DVD-VR375
Good luck.
Posted on Mar 06, 2009
Need the programming code for samsung dvd-vr375 thanks
Go to this site and put you make and model number in the search bar and you will be able to get the manual for your dvd player. http://tv.manualsonline.com/support/other/flat-panel-television/instruction-manual
Dec 17, 2014 | Samsung DVDVR375 DVD & VCR Combo Recorder...
Lost users manual for sumsung P1000
Please click on the link below to be able to access the manual of your samsung dvd-vr375 recorder/vcr combot thi
The exact manual for Samsung DVD-VR375 DVD Recorder / VCR Combo is not available but this is the best manual that fits in for your Samsung DVD-VR375 DVD Recorder / VCR Combo
http://www.samsung.com/africa_en/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=501&prd_mdl_cd=DVD-VR355%2FXFA&prd_mdl_name=DVD-VR355&srchword=DVD-VR355
paste the link in the url position and download the manual.
Hope this helped.
Jun 21, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
How do I set this Samsung DVD-VR375 DVD Recorder / VCR Combo to output 480i?
In the picture menu you should be able to adjust the resolution.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Unable to record free-to-air television. by the way the television is samsung
Does recorder have Digital receiver - meaning can you watch tv through the dvd recorder? If it's a year or two old, it may no be able to pick up the new digital signals.
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Jul 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Sep 05, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
