Question about GTCO CalComp ScanPlus III 1200T Path-Through Scanner
Scsi connection 50pin centronics
I HAVE SCANPLUS111 800T CONNECTED TO PC VIA 50 PIN CENTRONICS SCSI
I WOULD LIKE TO CONNECT TO SONY VIO PC USING A SCSI TO USB IS THIS POSSIBLE IF SO WHAT DO I NEED I.E DRIVERS
AND SOFTWARE
    Sergeant:
    Champion:
  • 224 Answers
You can download the drivers from the link below. This should work fine,
http://www.gtcocalcomp.com/supportscannersoftwaresp3monoturbo.htm
Posted on Mar 06, 2009
  • 916 Answers
All the information you need can be found here: Click Here
  • 13,433 Answers
The old scanner most likely wont function with a usb converter.
How can I connect Tandberg SLR60 device to a PC with windows XP? Device is installed but it is not listed in removable media section. There are no problems reported in device manager etc.
The SLR60 is a SCSI device. First you need to acquire a SCSI adapter, such as an Adaptec 29160 or 39160 PCI SCSI adapter. Both the adapter and the SLR60 have 68-pin connections, so you will need a cable similar to this one: http://www.cablestogo.com/product/07858/3ft-scsi-3-ultra2-lvd-se-md68-m-m-cable-thumbscrew. Once you have all of this, connect the tape device via cable to the adapter. You will need a 3rd-party backup program, such as Seagate Backup Exec or NovaBackup.
Jun 17, 2015 | Tandberg Computers & Internet
Connector question
dear,
well to rectify this problem you have 2 options:
1. either you can purchase a PCMCIA card with 50 pin Scsi connector.
2.or USB to SCSI convertor.
all this kind of connectors and convertor are available in IT shops
Regards
May 15, 2008 | Agfa DuoScan T1200 Flatbed Scanner
Getting Acer ScanPrimo ST 1220ST to work with Windows 7 and a PCI host adapter with an LSI20329IE Ultra 320 using a VHDCI 68 PIN TO CENTRONICS 50 PIN (CN50) CABLE
Acer ScanPrimo ST 1220ST to work with Windows 7 and a PCI host adapter works just fine I use it every day. The key is to use a third party scanner software called Vue Scan 9.0.57 and using the following start-up procedure so Windows 7 can find the scanner on the SCSI controller. First open windows device manager, then turn on scanner, immediately right mouse click in device manager and select scan for new devices. Windows 7 will immediately find the scanner. It seems that windows will only see the scanner through the SCSI interface during the scanners startup sequence. It has been a while but I believe this works with Mira Scan V4.03 as well.
Sep 22, 2011 | Acer ScanPremio 1220ST Flatbed Scanner
How do i use an epson filmscan 200 with a laptop running windows 7
were you using it under windows xp? if you have 32 bit windows 7 I would try those same drivers. Unfortunately the filmscan 200 came out under windows 95/98 and so Epson never released XP drivers and some people were able to make it work.
I would consider connecting it to an older computer running windows 98 and then transfer the files as you scan them (this would definitely be the least painful)
If you have 64 bit windows 7 I would not even waste the effort, 32 bit is a long shot maybe.
Do you have scsi drivers on the the windows 7? because the filmscan 200 is a scsi 2 device
Good luck
Nov 24, 2010 | Epson FilmScan 200 Film Scanner
I want to retrieve data from an old 50-pin hd from my old mac. Anybody got a solution?
There are two ways of retrieving data from a SCSI hard drive.
1. Connect the SCSI hard drive to a different SCSI connector on the same data cable, make sure this hard drive has a different SCSI ID from the first hard drive or other SCSI devices in your system. When you boot up your MAC you should see the second SCSI hard drive, You can then copy off your data or remove the redundant files and keep the old hard drive in your system as a 2nd hard drive.
2. Connect the old SCSI hard drive to a SCSI USB hard drive adapter. Then connect it to the USB port on the MAC and you should see this as an external hard drive.
Jun 14, 2010 | Ricoh 2GB Printer Drive (SCSI-50PIN)...
SCSI to USB connection
You would need a USB to SCSI (50 pin Centronics) adapter. That would get it connected, but i don't you are going to find any software or drivers that will then see the scanner so you could use it.
May 11, 2010 | Apple OneScanner 1200 Flatbed Scanner
SCSI Hard drives
i think you have two connections to SCSI drives not one to ide and one to scsi. anyway, if you have a SCSI controller card, you only need to connect do SCSI drives. only.
May 06, 2010 | Computers & Internet
I would like to connect my old SCSI coolscan iii
If your macbook doesn't have the correct SCSI card (SCSI II - d-sub mini 50 pin x2 connector) installed, you aren't going to be able to do this. You will need to find this SCSI card and install it in a computer that will accept it.
Rich
Dec 16, 2009 | Nikon Coolscan III Film Scanner
SCSI Inquiry Command Failure w/Tandberg TDC 4120 tape drive
Try putting the tape drive on the last scsi termination point.
Jan 01, 2009 | Adaptec Cables & Converters...
How do i connect a "fujitsu 4750 scanner to my PC.
my pc does not have a 50pin connector. so i need (i Guess) a converter that will go from the 50 pin to a usb on my pc?
thanks.
May 28, 2008 | Kodak Digital Science 3520DP Path-Through...
GTCO CalComp ScanPlus III 1200T Path-Through Scanner Logo
85 people viewed this question
Top GTCO Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a GTCO Office Equipment and Supply Expert? Answer questions, earn points and help others
