Question about Sanyo PLC SW20A Multimedia Projector
Colour settings Plugged a camera in to unit ( PLC-SW20A) and colour is now distorted.Need original settings for the projector. Urgent Please
  • 4,889 Answers
Here's a service manual it has the right settings. Hopefully it resolves the issue..Click on the link below to download.
http://www.mediafire.com/?mnty4nwymym
Posted on Mar 06, 2009
The orange coloured sanyo ultra short throw DP PLC - XE50 is cleaned regularly but still the unit doesn't allow the bulb to work.
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Aug 15, 2013 | Sanyo Office Equipment & Supplies
I have an Sanyo PLC-SU07E Multimedia projector. I
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Aug 09, 2013 | Sanyo PLC SW20A Multimedia Projector
My sanyo PLC-sw20a lamp does not light after turning on, the red lamp indicator still lighted and there is no indication for lamp replacement. Is the lamp busted?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
have a nice day!
May 20, 2011 | Sanyo PLC-SW20A Lamp
I hv Sanyo PLC-SU07N Projector - the image is blue
I have a possible solution however it may not be THE solution your after, you'll probably be able to tell very quickly if it isn't, this will only apply if you are using either a component video signal or a PC/laptop signal to send to the projector.
If you are using a laptop or desktop to hook up your projector, I would try first of all double checking that it's correctly plugged in, and if you still have no luck try a different cable.
It's likely to be the cable because when the signal goes down the cable it's split into 5 different signals. 3 of these are the colour information for Red, Green and Blue. Depending on what you mean by 'image is blue', it could mean that your either not getting the information for Red, or your not getting the information for Red AND Green. If you want to test this, open up microsoft paint while connected to the projector and create 3 boxes, then fill 1 completely red, 1 completely green and one completely blue. If you are missing the information to any of these colours then that colour will appear black on the projector screen.
In component video the signal is split down 3 cables (rather than 5) and 2 are colours (rather than 3)... Red and Blue. Check that the cable running red (Usually labelled Pr on the DVD and projector) is completely plugged in (some of these are really tight, but it's important that it goes all the way) and also that you have plugged into the correct slot, for instance that you have plugged into Pr and not the right Audio channel, both of which are coloured red.
If you are still not having any luck then I would suggest using a computer monitor or a television (depending on what type of signal your sending it) to test the projector. Plug it in instead of the projector and if it works then the issue lies with the projector and I have at least narrowed it down for you.
Hope this has been helpful.
Mar 28, 2011 | Sanyo PLC SU07N LCD Projector
Do i need to replace the bulb of my sanyo pro x multiverse projector (plc sw20a)?? it has a vertical lines
The bulb will not give that effect. A sharp bump or jolt will however by dislodging the LCD units.
Mar 24, 2011 | Televison & Video
Sanyo plc sw20a dose not work with my laptop what
you need to activate the external monitor port on your laptop.
Oct 04, 2009 | Sanyo PLC SW20A Multimedia Projector
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Green haze projected on wall
the Lcd panels were broken, you need a new one,USD120
have a nice day!
Oct 26, 2008 | Sanyo LAMP Projector Lamp FOR...
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Sanyo PLC SW20A Multimedia Projector Logo
139 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
