Question about Honda 6370C - Parallel Power Kit For EU3000i
Honda EU3000i is rated to put out 15A but won't
Honda EU3000i won't run my 15A electric log-splitter. It is rated to put out 15A but the power overload light comes on, and it won't send power to the log splitter. After browsing here, I'll next try turning OFF the eco-throttle setting. Any other suggestions? Will oil change, air filter clean-up, and such maintenance inprove performance?
Jim
  • 1 more comment
  • jim Mar 07, 2009
    Thanks for the comments, jtlap.
    Joboo1,
    The log splitter works great on household 120v power. It's from Canadian Tire, and is brand new.
    I plugged it straight into the genny to avoid adding resistance with an extension cord, but still no workie.
    I have the manual, if ther are more specs that would help I can type them in.
    Jim
  • jim Mar 24, 2009
    Hi joboo1. Thanks for helping me with my EU3000is honda generator and 15A electric log splitter. I got a chance to try your suggestions and was able to split wood using the locking plug.
    However, using the locking plug I see the red light (overload indicator) comes on for about 2 seconds and then goes out. The manual seems to indicate this is ok but what do you think?
    I'm planning to clean the air filter, change the oil, etc. as my genny is 2nd hand and I think maybe 5 years old. No idea how much run time.
    Anything else you'd recommend?
    Thanks again for your time and expertise.
  • Jim London
    Jim London May 11, 2010
    Hi, A 120v 15A log splitter? do you have more details on the log splitter? What kind of cord are using to the splitter ( how long). Did it ever work OK? Long distance troubleshooting is tough, more details will help.
If you attempt to use a 15 amp generator to power a 15 amp appliance you will have a big problem. Always plan to use no more than 80% of any power supply. You are currently trying to use the absolute maximum power this generator can supply, and it's probabally not rated for that load at continious use. Get a larger generator, or , a very sharp axe.
I hope this information was useful for you.
Joe
Posted on Mar 06, 2009
  • jtlap Mar 07, 2009
    More specs wont help, more power will. There's nothing wrong with your generator or the splitter, It's like this, the most you can use on a 20 amp circuit is 16 amps, and only 12 amps max on a 15. thats just the way it works.
  • 257 Answers
Hi, Well, at this point I would try a couple of things depending on the age of the genset. Definitely turn off the eco throttle. The 120v duplex plug is rated at 20amps but varies with run speed so lets assume it is close and the specs a little loose. Change the plug to the 125v locking plug which at full speed is rated at 30 amps and see if it holds. The rest would be dependent on age . This genset has a 2 year residential warranty and if it is under I would have it repaired under the warranty. I would at the very least test it or have it tested to see what the overload is tripping out on. My best guess from here is the overload circuit board if everything runs correctly. We use this genset out in the field for bull testing equipment and haven't had a problem like this even with an extension, (we use the locking plug). As far as your overhaul, if the genset is running up to speed and doesn't bog down it is probably OK. If you hear any difference in speed at all when you plug something in, change the oil, filter and spark plug and check your carb settings. Good Luck, let me know what you find out, hope this Fixsya!
Posted on Mar 07, 2009
  • Jim London
    Jim London Mar 24, 2009
    Hi Jim, I think your splitter is pulling the max so the only other suggestion to squeeze out any more is to check the wire size from the splitter, if it is rated for 15 amp the wires size is probably a 12 gauge or less. Most appliances do not run at full faceplate rating all of the time, but it sounds like your splitter is running close, so a bigger wire size won't hurt and will even fit your locking plug a little better. If you have room from your splitter try a 10 gauge. Glad we at least got you going! Let me know how it works out for you! Thanks
Timber tuff 5 ton eletric log splitter will not move
check/replace the start/run capacitor/s
check that the hydraulic pump is not seized
Oct 26, 2015 | Timber Tuff 5-Ton Electric Log Splitter
The remote start for my honda eu3000is will not shut it off
Bad earth connection to the key switch as these magneto types only earth the coil wire to turn ignition off. Check for loose connections or faulty switch
May 18, 2014 | Honda 6370C - Parallel Power Kit For ...
Electric log splitter motor hums but won't run
suggest you get information on repairing log splitter, not dryer. have the same problem, and no replacement parts available. must be in the electrical, easiest would be capacitor, less the motor itself, take apart and see if windings burned, or smell electrical
Oct 13, 2012 | Dryers
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
Just got a log splitter cantget started motor running it moved and blew fuse
Hi, not much info to go on here, but;
have you ensured that your outlet automatic fuse (if applicable) will handle the current of the electric motor? Check ratings. If motor rating is close to automatic fuse limits, you will need a "slow" type auto fuse or use a larger capasity outlet. This the first thing to check before looking further at the splitter itself, assuming that it is the fuse of your outlet that you blew?.
Kjell
Jul 14, 2011 | McCulloch 4 Ton Electric Log Splitter #...
Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Feb 26, 2010 | Honda 6370C - Parallel Power Kit For ...
My honda eu3000 electric start quit working. I
Hi, You need to check the ignition plug behind to ensure it is still working fine. You will need a spanner for this and unscrew it anticlockwise.
THanks
Dec 09, 2009 | Honda 6370C - Parallel Power Kit For ...
Honda 6370C - Parallel Power Kit For  EU3000i Logo
867 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
