Question about Dryers
Whirpool LGR7646DQ0 dryer won't start -can hear timer running, timer stops when door switch is pushed, but dryer will not start.
  • 1 more comment
  • macheski
    macheski Mar 06, 2009
    mildcooksey...thanks for the suggestion, but I don't think touching two wires together while plugged in sounds very safe! Also, what do you mean by "continuity to fuse"? Are you saying the fuse itself could be shot? Wouldn't a fuse stop the timer from working? Or are you saying something is not getting to the fush? I can hear the timer working, but the dryer won't start. Seems like the timer wouldn't work either if it was a fuse...but that's what I'm asking before disassembly, ok?
  • macheski
    mildcooksey...Yes, keeping it unplugged seemed like common sense to me, but your comment wasn't written clearly. Along those lines are there not connectors to the fuse? Do I remove the fuse first, then just align wires so the bare suface is touching or are there connectors?
    Again, why does the timer continue to run if it indeed is the fuse? I can clearly hear the timer running.
    Thanks!
  • macheski
    macheski Mar 31, 2009
    mildcooksey had it completely wrong...the thermal fuse he referred to had nothing to do at all with the problem. As I stated the timer would run, but dryer would not start.
    Turns out the timer itself was defective-not allowing the relay with timer to kick properly, thus dryer wouldn't start.
  • 163 Answers
There is a white fuse in back of machine.take back panel off and check for continuity to fuse.you can also put the two wires together and plug your machine in and make sure nothing is touching,and hit start button.UNPLUG FIRST.the fuse sits on blower housing.it will be white with a black strip down the middle and only two wires.
Posted on Mar 06, 2009
  • 1 more comment
  • mike cooksey Mar 06, 2009
    UNPLUG FIRST,take back panel off.that fuse runs the dryer.if you put the two wires together and put electrical tape around end and plug dryer back in hit the start button and i bet that fixes your problem.you need a fuse.I hope you wouldnt touch any wires while machine is plugged in.common sense.
    some dryers have a cutoff switch if your belt breaks.but sounds like fuse.
  • mike cooksey Mar 31, 2009
    I was just sugesting to check fuse before buying a timer.I dont know what you couldnt understand,but without being their to see what is going on and just getting little info from you I give some other things to look for besides the timer.
Dryer intermittently not starting.
The rat chewed up the power line and caused it to short out. Kill the rat!
Jul 14, 2013 | Whirlpool Dryers
Rgx4634kq2
make sure push start switch is not stuck pushed in.Also sounds like the switch mounted on the motor could be stuck, which means new motor. Does motor start and stop with timer being moved to the off position ?.If so then not the motor.
Jul 01, 2013 | Dryers
Dryer want start up
There are several reasons why this may occur:
1. Open the dryer door and look for either a small lever at the top of the hole which through which you put your clothes or a small hole with a lever inside that can be moved with a pencil or screwdriver.
If you see a small lever near the top, push the lever in and see if you hear a slight "click". If you do, set the timer to dry, push the start button WHILE PUSHING THE LEVER IN. If the dryer starts, the metal lever you are holding may have gotten bent inward. Let the lever go and bend it a little further out. Then insure that the door makes contact with the lever as it closes and pushed the lever in enough to hear that click. Close door and try to start dryer again.
The same procedure will be used for the other type of switch. If there is a hole, use a screw driver to insert in the hole and push the lever to hear a click. Opposite the hole on the inside of the door should be a tab, or a finger type object that, when the door is closed, will insert itself in the door and push the lever. If this finger is missing or broken, it must be replaced. If the finger is there, stick the screwdriver into the lever and try to start the dryer. If it works, insure the finger is aligned to enter the hole properly.
If the dryer does not start with any of these tests, you may have a bad door switch, which we were testing. We will need to check:
1. That you have power to the unit. 2. That the dryer cord and terminal are ok and in working order. 3. If the thermal fuse is ok. 4. If your timer is working properly.
To troubleshoot further, I'm going to need the make and model number. The make (Kenmore, Crosley, Whirpool, GE) should be on the console. The model number may be on the inside of the door or on the back of the unit.
I look forward to assisting you further.
Aug 02, 2010 | Kenmore 64742 Electric Dryer
I only hear a click sound when I push the start button. Model Lf5751XFW0 whirpool
Open the door when you hear the clicking sound. If it stops. Check your door switch check you non settabele limiter on your heater.
Apr 22, 2010 | Dryers
Dryer will not start
It is possible that the door switch is defective. Switch is on inside of front panel. If so you have to dismantle dryer to remove switch.This switch will prevent motor from starting. Is timer running? You should be able to hear small motor running near timer. If not, make sure 240 volt breaker is not tripped. Dryer motor and timer only run on 120 volts and heating element uses 240 volts. So, if one side of 240 volt circuit is dead it may be the side of the circuit that powers motor. Try flipping breaker off and on again. If possible, check circuit with volt meter ONLY if you know how to. If not, get a tech to check out.
Jul 21, 2009 | Whirlpool WGD5300S Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Dryer wont come on
check the voltage at the outlet for 220
Feb 16, 2008 | Roper REX4634KQ Electric Dryer
Kenmore series 70 mod#110.62722100
check the door switch first if it is ok ..(doors not popping open) then the PTS (push to Start) switch is most likely bad as it wont hold in after it was pressed
Jan 25, 2008 | Dryers
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
132 people viewed this question
Top Dryers Experts
