Question about Acer Aspire 5315 Notebook
The driver fur audio driver not installirt.(code 28=
The driver fur these devise not installirt.(code 28)
Install the driver
in device maneger in audio driver i do click,then message
(the driver fur these devise not installirt)
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard, aber no funktion
not activ.
tank
  • Acer Master
  • 19,396 Answers
Guten morgen, ich werde schreiben in English weil mein Deutsch ist nicht gut.
You need to download the drivers from the Acer Website, and then install drivers after download has finished.
Follow instructions on page below to download drivers:
Acer Europe - Service & Support, Drivers & Utilities
Run driver installer after download is complete.
Unplug printer USB when you start driver installation, the program will tell you when to re-connect.
Posted on Mar 06, 2009
    Sergeant:
  • 239 Answers
You can download the drivers from here.
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%205315.pdf?CFID=5207740&CFTOKEN=49521309
Hope this helped
please rate well.
Driver for iphone4 code 28
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue. Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Jan 08, 2012 | Microsoft XP Computers & Internet
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Resolution
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
Mar 01, 2011 | HP Computers & Internet
Hello me Audio device not work a small yello triangle apear in device maneger (multimedia Audio controller)
reinstall the driver, download a new driver from the manufacturers website to the desktop then uninstall the device from the device manager then restart the computer then install new driver you have downloaded.
Jan 18, 2011 | Intel D865GSA (BOXD865GSAL) Motherboard
I dont have driver for my audio. I have code 28 error
Code 28 The drivers for this device are not installed. (Code 28)Recommended resolution
Install the driver
You may be prompted to provide the path of the driver. Windows may have the driver built-in. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to install the driver.
Jun 21, 2010 | Microsoft Windows XP Professional
Code 28, and go into device manager and multimedia audio controller has yellow ! mark and its under other devices, i am running windows xp, any suggestions?
Hi Friend,
Please follow the below steps,
Step 1: Go to Deice Manager
Step 2: Rightclick on the which prompts Code 28 Error and click on UPDATE
Step 3: It will run the Update Wizard and it will install the Latest Driver for the device and it will stop the error code 28
Regards,
Aysaam
Jun 09, 2010 | Computers & Internet
Code 28
Install the driver
Mar 27, 2009 | Microsoft Windows XP Professional
You can get the drivers from the link below.Although it shows as Vista, it is also compatible with XP. Give it a try and let me know if it works
http://support.acer-euro.com/drivers/notebook/as_5315.html
Mar 06, 2009 | Acer Aspire 5315 Notebook
Code 28 drivers
how do i fix code 28 for free
Apr 14, 2008 | Microsoft Windows XP Professional
Acer Aspire 5315 Notebook Logo
210 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
