Question about Xerox WorkCentre Pro 555 Plain Paper Laser Fax
We send and receive several faxes a day from several different sources. We are having an issue with one source in that we can send them a Fax and they receive it...but when they send us a Fax we do not receive it. They claim the issue is only with us, as they also send and recieve from several sources. What would you suggest?
    Genius:
  • 2,120 Answers
They are sending your faxes to some other fax number. Guaranteed. They probably use a misconfigured speed-dial entry to send to you.
Posted on Mar 07, 2009
Can't send fax, can only receive
you can't send the fax, the paper don't feed, you need to clean the paper path the roller that guide the paper to pass under the the scanner must be cleaned with alcohol. you need to unplug the fax from the power source. after cleaning wait for 10mn and try to send a fax.
Dec 23, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Unable to send or receive a fax
please check first the connection at the back of the printer. Sometimes the cause of not able to send and receive fax is due to connection issue.
If a phone is attached with your printer, the rj11 cable from the phone should go to the phone input of the printer.
While the line source should go to the "L" or line input at the back of the printer. then after that try send fax again.
Oct 14, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Canon printer 5440 "unable to print see troubleshooting routine maintenance manual" - message in led window
Open the scanner cover and remove any
foreign obstacles from inside the MFC. If the
error message continues, please follow the
steps below before disconnecting the MFC so
you will not lose any important messages.
Then, disconnect the MFC from the power
source for several minutes (which will erase all
faxes), and then reconnect it.
Check whether the MFC has faxes in the
memory
1. Press Menu/Set, 9, 0, 1.
2. If the MFC has no faxes, disconnect the MFC
from the power source for several minutes
OR
If faxes are present, you can transfer them to
another fax machine. Go to Step 3.
OR
You can forward the faxes to your PC. Please
see Transfer faxes to your PC.
Transfer faxes to another fax machine
If you have not set up your Station ID, you
cannot enter fax transfer mode.
3. Enter the fax number to which faxes will be
forwarded.
4. Press Black Start.
5. After the faxes are transferred, disconnect
the MFC from the power source for several
minutes and then reconnect it.
You can transfer the Fax Journal report to
another fax machine by pressing Menu/Set,
9, 0, 2 in Step 1.
You can move the faxes from your MFC’s
memory to your PC.
1. Press Menu/Set, 2, 5, 1.
2. Using ▲ or ▼, select PC Fax Receive, and
then press Menu/Set.
The LCD will ask if you want to transfer a fax
to your PC.
3. To transfer all faxes to your PC, press 1.
OR
To keep all faxes in the MFC’s memory,
press 2.
4. After the faxes are transferred, disconnect
(For details see Using Brother PC-FAX
software
on page 5-1 in Software User’s
Guide on the CD-ROM.)
These steps is on user manual.
Jan 16, 2010 | Brother MFC-5440 Printer
I have received a fax and it has to vertical lines down the front of it.
The problem is with the SENDER's fax machine ... not yours...
Your fax machine is working properly...
Note that all faxes from that source will have the stripes, all other faxes that you receive from other sources will not have the lines...
You might send the fax with the lines back to the sender to advise them...
Hope this helps!
Sep 09, 2009 | HP Office Equipment & Supplies
Sending and receiving fax on legal size paper on
What's the question? You can send a fax on legal size exactly as you do with lettersize. As for printing, you only have 1 size of paper available at a time (1 paper source) , so put legal in it if you want.
Apr 12, 2009 | HP LaserJet 3050 Printer
Cannot receive!!!
have you tried connecting it to another telephone line, also try replacing the fax lead
Mar 10, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Problem receiving fax from outside source . phone rings acknowledges receive on screen but no fax comes through. other source sends faxes to other sources no problem & i receive faxes from other...
In the last statement you said you RX faxes from other sources? which means you can't RX from one or a certain source??
1- could be area code
2-could be your memory is almost full and their faxes are too long
Jul 31, 2008 | Samsung Office Equipment & Supplies
Unable to init.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. ?OR? A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. ?OR? You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. ?OR? To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 06, 2007 | Brother MFC-5840CN All-In-One InkJet...
Fuser Error
If your unit is out of warranty, sadly but true go get a new equipment. Xerox will probably charge por parts and service almost what you paid for the equipment.
Oct 25, 2006 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Xerox WorkCentre Pro 555 Plain Paper Laser Fax Logo
207 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
