Question about Sony Car Audio & Video
Sony CDX-F7705X wiring diagram
I have a fordwindstar i removed the cassett player iam installing a sony cd player i did buy the wire horness not sure about diagram.
which wire coresponds to which i have a meter i can measure the voltage. but not sure which wire gets connected to which wire color codes don't match.
4 Suggested Answers
mixmaster
  • 626 Answers
SOURCE: i need a wireing diagram for sony cdx-l580x
Found it HERE.
Best of Luck.
Please RATE my solution BELOW.
Posted on Nov 28, 2007
Nomodo4u
  • 863 Answers
SOURCE: need a wiring diagram to install cd player
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address2_bing.gif.
Here you go bud:
http://cgi.ebay.com/SONY-wire-WIRING-Harness-XPLOD-XR-CA430-CDX-MP30-sn6_W0QQitemZ200417888633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9d64979
Posted on Feb 23, 2010
iadame
  • 676 Answers
SOURCE: CDX-RA700 CD Player: My wires on my sony CDX-RA700 do not match my 2005...
The following should help you. Good luck. Please rate. Radio 12v orange + radio harness Radio Ground black/orange - radio harness Radio Ignition yellow + radio harness Radio Illumination brown/white + radio harness Factory Amp Turn-on lt. green + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - black +,- radio harness Notes: If equipped, the amplifier is in the passenger side of the trunk. RF Speaker +/- blue - red +,- radio harness LR Speaker +/- white - brown +,- radio harness RR Speaker +/- orange - green +,- radio harness
For the stereo the following will work.
Posted on May 07, 2010
SOURCE: sony cdx f5700 wiring diagram
aux should be 2 point cuming off wive the wires or on the back ov the cd player and red and yellow needs 2 be touching for you live and you earth is the thickest black wire if that dont work then try the fuses
Posted on Aug 03, 2010
I want to install a Sony CDX-SW200 cd player in my car and need to find a wiring diagram. Where can I find one?
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address.
Here you go bud:
Feb 23, 2010 | Sony CDX-SW200 AM/FM Compact Disc...
Need a wiring diagram to install cd player
Here you go bud:
Jan 13, 2010 | Sony CDX-SW200 AM/FM Compact Disc...
Need wirin diagram for sony cdx-gt310
http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
Here is the schematic you need.
I would advise buying the aftermarket wiring harness female/male so you can just plug it in.
Feb 08, 2009 | Sony CDX-GT310 CD Player
Wiring Diagram For Sony Disc Player
how do i install a cdx-s2210 to my 92 camry..what wires do i connect?
Jan 02, 2009 | Sony CDX-S2210 CD Player
I need a wireing diagram for sony cdx-l580x
Found it HERE.
Best of Luck.
Nov 28, 2007 | Sony CDX-L580X CD Player
SONY EXCD-206 December 1996
I have the same radio, the radio's harrness has a red wire ignition 12 volt,yellow battery 12 volt, black ground, and a blue Iam not positive it can be the amp, or illumination.
Nov 18, 2007 | Sony CDX-CA400 CD Player
Car Audio & Video Logo
1,117 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
