Question about HP Office Equipment & Supplies
Displays error 1706 every time i use nmy computer
    New Friend:
  • 52 Answers
Displays error 1706 every time i use nmy computer - error_x.jpg What Causes Error 1706 Error 1706 is a critical Windows error and is caused by a corrupt registry entry that should be repaired immediately to prevent further corruption in other applications and/or hardware. Risks include hardware failure, blue screen errors and fatal crashes. I found this on the internet by typeing in Error 1706 at google. If you have Norton Tools you need to runit or some other Registery Repair software.
Posted on Mar 06, 2009
Hp 6930p nmi channel check iochk
System I/O address specifications 970-071 NMI enable/RTC
What is Nmi Error On Hp Server error? The Nmi Error On Hp is the Hexadecimal format of the error caused. This is common error code format used by windows and other windows compatible software and driver vendors.
This code is used by the vendor to identify the error caused. This Nmi Error On Hp Server error code has a numeric error number and a technical description. In some cases the error may have more parameters in Nmi Error On Hp Server format .This additional hexadecimal code are the address of the memory locations where the instruction(s) was loaded at the time of the error.
What causes Nmi Error On Hp Server error? The Nmi Error On Hp may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
How to easily fix Nmi Error On Hp Server error? There are two (2) ways to fix Nmi Error On Hp
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Nmi Error On Hp Server) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Dec 10, 2016 | HP Computers & Internet
Icannot get rid of the folliowing: Error 1706 Win DVD.
hi there,
May you provide the complete details of your player like the maker model..
`jack
May 23, 2008 | HP Televison & Video
How to stop Microsoft Powerpoint error 1706?
Causes of Error 1706 ·Corrupt download or incomplete installation of Microsoft Powerpoint software.
·Corruption in Windows registry from a recent Microsoft Powerpoint-related software change (install or uninstall).
·Virus or malware infection that has corrupted Windows system files or Microsoft Powerpoint-related program files.
·Another program maliciously or mistakenly deleted Microsoft Powerpoint-related files.
Runtime Errors such as "Error 1706" can be caused by a variety of factors, so it is important that you troubleshoot each of the possible causes to prevent it from recurring.
If you are still experiencing the issue you can try PowerPoint Fix Toolbox https://www.fixtoolbox.com/powerpointfix.html
Jul 26, 2015 | Microsoft PowerPoint for PC
Nmi error
Chip-set or memory error that relates to parity or ECC (error correcting) Try singling out your system memory and see if you still get this error.
Feb 05, 2014 | IBM Xseries x346, 1 x xeon 3.6 ghz/1 mb,...
When boot up my computer and my XP operating system, I get a pop up window which reads: ERROR 1706 VALIDATE SOURCE CANNOT BE FOUND FOR PRODUCT DAO The WINDOW INSTALLER continues to try to install...
Error 1706 is usually displayed at run time when a program is installed using Install Shield. You can fix it or install the files by accessing the bios setup.. On the boot section choose the drive where the file to be installed is located to be the first one to boot. If it is on the CD drive choose Cd drive then save and exit setup.
Jul 14, 2011 | Computers & Internet
HARDWARE MALFUNCTION CALL YOUR HARDWARE VENDOR FOR SUPPORT NMI : PARITY CHECK / MEMORY PARITY ERROR THE SYSTEM HAS HALTED what should i do now
Hello sumeetbapu,
Here are 2 suggestions which might be helpful in determining the cause of the nmi error:
• 1. Use the Windows Memory Diagnostic tool to test the RAM on your computer:
http://oca.microsoft.com/en/windiag.asp
• 2. Review this article from Microsoft Developers Network: What does an NMI error mean?
http://blogs.msdn.com/b/oldnewthing/archive/2007/02/27/1769274.aspx
Finally, you may need to replace a memory module. If you need help with replacing the memory, please be sure to ask.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 07, 2010 | HP Pavilion dv6000z Notebook
NMI ISSUED PRESS ESC TO TURN OFF NMI IN IBM SERVER
dear mugkifa ,
the above error indicates , a non maskable interrupt occurred in your server , there may be a change of malfunction of a hardware ,like add on cards
one more solution in ibm server is disablig the NMI interrupt by using jumper settings (inside motherboard)
see the below mentioned details , may differ with your server series please refer with series on http://www-947.ibm.com/support/entry/portal/docdisplay?brandind=5000008&lndocid=MIGR-5069937
System-board jumpers
The following illustration shows the switches and jumpers on the system board:
migr-5069937_2.gif Note: Any jumper blocks on the system board that are not shown in the illustration are reserved. The following table describes the function of each jumper block:
Jumper Settings CMOS jumper (JP3) Pins 1 and 2: Keep CMOS data (default)
Pins 2 and 3: Clear the CMOS data, which clears the power-on password and administrator password Boot block jumper (JP4) Pins 1 and 2: Normal (default)
Pins 2 and 3: Recover boot block NMI (non-maskable interrupt) switch (SW1) Normal (default): No NMI issued
The NMI button that is on the rear of server, connected to this switch, has been pressed: NMI issued
May 07, 2010 | IBM eserver xSeries 360 8686
Error 1706
Try to use the Registry cleaner software e.g.
Registry Cleaner or RegCure
these two softwares should help you to remove the unwanted registry entry which are raising the problem of "Error 1706"
May 30, 2009 | Microsoft Windows XP Professional for PC
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
Navigation fatal error Error 1706
yes..I saw that..need teh model number of the actual gps you are using, please..
Mar 09, 2008 | GPS
243 people viewed this question
Seeker5211
Seeker5211
