Question about Whirlpool Timer Clock Knob
Whirlpool LGR7646DQ0 dryer won't start. Can hear timer running, and timer stop when door switch is engaged.
SOURCE: Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Posted on Jan 24, 2008
SOURCE: whirlpool thin twin dryer starts and stops after 5 seconds
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
Posted on Mar 19, 2008
SOURCE: whirlpool dryer
The following link will give you some additional advice on how to troubleshoot a dryer:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Read through the link provided, thoroughly. It does cover many common dryer problems and how to diagnose them.
You know at this point that have power to the unit, because the drum light is working. Now...with the door open, does the light go out when you push the door switch in by hand? Is that how you determined the switch to be good? If the light does not go off, the switch may not be working properly and the dryer will not start. Another easy item to check is the thermal FUSE. The fuse is located behind the lower panel under the door. It is a white plastic component mounted to the top of air blower housing right under the drum in the front. There should be two wires going to it. If the thermal fuse is good, it should read a short (or close to zero ohms). These two first items I mention will kill a dryer from starting and are the most common problems to start with. Read through the section "Dryer Does Not Run at All" and let me know if require further assistance. I hope you find this information helpful.
Posted on Nov 08, 2008
SOURCE: Dryer won't start - Whirlpool LER7646EQo
IF THE DRYER DOES NOTHING AT ALL I WOULD SAY YOUR MAIN FUSE HAS BLOWN,IT IS ON THE BLOWER BOX AND IS WHITE,YOU CAN REMOVE THE BACK PANEL AND CHECK IT WITH AN OHMS METER,IF YOU GET NO READING IT IS BAD,LET ME KNOW-MIKE
Posted on Feb 23, 2009
SOURCE: Whirlpool Dryer LER7646EQO - Won't Start
my whirlpool electric dryer not turning,there anyone can help
Posted on Mar 27, 2009
Jul 14, 2013 | Whirlpool Dryers
Sep 03, 2012 | Estate by Whirlpool Dryers
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
Nov 16, 2011 | Dryers
Apr 18, 2010 | Whirlpool LER5636P Electric Dryer
Mar 06, 2010 | Dryers
Mar 30, 2009 | Dryers
Mar 06, 2009 | Dryers
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
Dec 23, 2007 | Kenmore 63942 Dryer
Nov 12, 2017 | Whirlpool Hardware & Accessories
Sep 27, 2016 | Whirlpool Hardware & Accessories
69 people viewed this question
