Question about Philips Philishave HQ7782 Electric Shaver
Warning light - Philips Philishave HQ7782 Electric Shaver
    Problem Solver:
  • 6 Answers
Here is a link to the owners manual for the HQ7785 Electric Shaver. If this is the wrong model, your manual may be listed at this site as well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
Posted on Apr 16, 2009
The spot for brakes on the dashboard has an IP lite up on it. what does that mean?
CHECK OR HAVE SOMEONE CHECK BRAKE FLUID LEVEL, BE SURE PARKING BRAKE IS NOT ON!
Jan 22, 2016 | Cars & Trucks
Warning lights panel doesn't come on. No warning lights.
Check your ground connection to the warning light cluster. Either the ground wire has come loose or the connection to the chassis has corroded.
May 07, 2015 | 2000 Dodge Caravan
I have a 2004 Jeep Cherokee Laredo. An indicator (with a symbol of what looks like a radiator) below the low fuel indicator (bottom left had side of the dashboard) lights up and remains on. I have checked...
2005 Instrument cluster layout
1. Speedometer
2. Brake warning light
3. Turn signal indicator light
4. High beam indicator light
5. Malfunction Indicator Light (MIL)
6. Airbag warning light
7. Anti-Lock brake warning light
8. Tachometer
9. Security alarm indicator light
10. Oil pressure warning light
11. Electronic Stability Program (ESP)/
Traction Control System (TCS) indicator light
12. Tire Pressure Monitor warning light (base)
13. Temperature gauge
14. Electronic Vehicle Information Display
15. Tow/Haul indicator light
16. 4WD Low mode indicator light
17. Seat belt reminder light
18. Cruise control indicator light
19. Odometer/Trip Odometer
20. Transmission gear indicator
21. Fuel gauge
22. Electronic Throttle warning light (5.7 Hemi)
23. Front fog light indicator light
24. Voltage warning light
Jun 05, 2011 | 2004 Jeep Grand Cherokee
One of the dummie lights is on and I am not sure what it means. Its the round one on the bottom right.
1. Brake warning lights. 2. Charge warning light. 3. Oil pressure warning light. 4. Coolant temperature warning light. 5. Coolant level warning light. 6. Engine management system warning light. 7. ABS warning light. 8. Airbag or SRS warning light. 9. Glow plug warning light 10. Water in fuel warning light 12. Low fuel warning light.
Not sure what light I would be on the bottom right but I hope this helps.
Good Luck!
Nov 03, 2010 | 2000 Volkswagen Beetle
2003 Cavalier. Battery warning light came on
check the wire from the battery to the starter to see if it has good connection. otherwise check your ground to block.
Mar 20, 2010 | Chevrolet Cavalier Cars & Trucks
Does the 1992 dodge dakota automatic trans have a fuse to overdrive button
The fuse number is
#16 - 5 Amp (Tan)
Gauges & Indicator Lights: Low Oil Light, Low Washer Light, Service Reminder Light, Transmission Oil Light, Brake Warning Light, Anti-Lock Brake Warning Light, Fuel Pacer Light, 4WD Indicator Light, Malfunction Indicator Light, Warning Buzzer, Overdrive Switch (1992-93); Transmission Oil Temperature Lamp, 4WD Lamp, Overdrive Module Seat Belt Warning Buzzer
(1994-95).
Jan 25, 2010 | 1992 Dodge Dakota
There is a light on the dashboard that I do not
I believe it's the washer fluid light
Here's a list of your dash lights and their meanings
Left
1. Door-ajar warning light
2. Oil pressure warning light
3. Check engine warning light
4. Tour or Sport for the ECS
5. Security indicator
Center Warning Lights
1st space down
Left: 4-wheel steering oil level warning light
Right: Brake warning light
2nd space down:
Left: Anti-lock brake warning light
Right: Active Exhaust Tour indicator
3rd space down
Left: cruise control indicator
Right: cruise control ON indicator
4th space down:
Left: charging system warning light
Right: High-beam indicator
Right Warning Lights
1st down: Not used
2nd down: Seatbelt warning light
3rd down: Washer fluid (2 storage containers)
4th down: Supplemental restraint system (SRS) warning light
Oct 07, 2009 | 1994 Dodge Stealth
I have a 2001 hyundai elantra and the warning lights on the dashboard. I know what the oil light looks like and the airbags. What are the other two lights.
Your best bet is to go HERE and signup for a free account then Downloading your Manual - service sheets, diagrams, parts lists etc.
Hyundai is one of the best with providing their customers with free information about the vehicles!!
I have D/L the manual, and the warning lamps on the instrument cluster are...
Left to right...(starting under temp. Gauge)
WITHOUT TRIP COMPUTER
11. Traction Control Indicator Light (If installed)
12. ABS Warning Light (If installed)
13. Seat Belt Warning Light
14. Oil Pressure Warning Light
15. Charging System Warning Light
16. Parking Brake/Brake Fluid Level Warning
Light
17. Malfunction Indicator Light (MIL)
18. SRS (Airbag) Warning Light
19. Trip Odometer/Odometer
20. Trip Odometer Reset Knob
21. Low Fuel Warning Light
WITH TRIP COMPUTER
7. Front Fog Indicator Light (If installed)
8. Door Ajar Warning Light
9. Trunk Lid Open Warning Light
10. Parking Brake/Brake Fluid Level Warning
Light
11. Malfunction Indicator Light (MIL)
12. Charging System Warning Light
13. Oil Pressure Warning Light
14. SRS (Airbag) Warning Light
15. Cruise Indicator Light (If installed)
16. Seat Belt Warning Light
17. ABS Warning Light (If installed)
18. Traction Control Indicator Light (If installed)
19. Automatic Transaxle Position Indicator Light
(Auto T/A only)
22. Low Fuel Warning Light
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 21, 2009 | 2001 Hyundai Elantra
Dashboard warning lights.
The warning light that looks like a pot or kettle with arrows is the "Low tire pressure warning light*" I found the answer on the Toyota web site by registering, logging in, entering my model and searching the owners manuals for warning lights.
Jan 16, 2009 | 2007 Toyota Sienna
Philips Philishave HQ7782 Electric Shaver Logo
220 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
