Question about Cameras
My sony dsc-w90 has just started to say "reinsert memory card". I have cleaned card and now bought a new card to no avail. Seems to be a fault with the camera which is about 18months old. Can I fix this fault? Best regards Dave Friston
  • david_fristo Mar 06, 2009
    my sony dsc-w90 has just started to say "reinsert memory stick". I have cleaned card and now bought a new card to no avail. Maybe a fault with the camera which is about 18months old? Can I fix this fault? I have tried reformat card in Menu but it wont format, just repeats "Reinsert Memory Stick". Best regards Dave Friston
    Many thanks for the advice
    Dave Friston
  • Cameras Master
  • 19,396 Answers
Try cleaning the contacts in memory card slot, if that does not work, then the camera has a lose contact to the memory card reader slot.
Posted on Mar 06, 2009
  • 916 Answers
You have an internal fault in the camera. Sounds like you may have a broken pin. A repair shop should be able to fix this very cheap. I would not attempt doing it yourself as it could damage the camera worse if a mistake is made.
  • 13,433 Answers
Does the camera work without a memory card? Please try a smaller one, what size are you using now?
  • Ekse Mar 06, 2009
    It appears the camera can't read the memory stick, try formatting it on your computer for FAT if that doesn't work try FAT32.
    IF this doesn't improve the problem at all, then the cardreader on the camera is possibly faulty.
  • Ekse Mar 06, 2009
    Plug the card to your computer, open my computer, right click on the card and select format. Then format the card.
  • 10,594 Answers
Please go to camera menu and try to format memory card and then check, does camera gives same error.
  • Shahid Electronics
    Shahid Electronics Mar 06, 2009
    memory card holder pins seems damaged so camera gives you error message. In this case main board of camera will be replaced.
    You should contact Sony service center for fix.
How can I solve my sony cyber shot camera modal DSC W630 is shows error as C13:01
This error indicates a memory problem.
The camera can't read or write data to the memory card. Try turning off and on the camera again, or take out and reinsert the memory card several times. Also remove and reinsert the battery.
It also can mean the memory card is not formatted, or there is a format error for an other reason. Format the internal memory or the memory card.
It also could mean the memory card is damaged and can't be used any more. Then you have to place a new memory card.
I hope something will help.
This is also in you user manual.
Mar 19, 2014 | Sony Cyber-shot Dsc-w630 16.1mp Digital...
Reinsert memory card in Sony Cyber-Shot DSC-H70
Clean contacts on the card with rubbing alcohol.. if not buy a new chip.
Aug 29, 2011 | Sony Cyber-Shot DSC-H70 Digital Camera
My sony says that my memory card is locked
If u are using a mini sd card then on the card itself there will be a lock. make sure that the lock is down.
Feb 21, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
My sony cyber shot model # DSC-W220 was working fine, I took 3 pictures today, when I took the memory card out and put it in my printer it said reinsert memory card, so i put it back in my camera and it...
Dear Friend,
From the description you have given, it appears that the Memory card has developed some problem.
Sony has defined Self Diognostics for their product. It will be displayed when the fault occurs. In your case you can try to resolve your problem in the following steps:
  1. Contacts of the Memory card is dirty or corroded. Clean it with After Shave lotion or Iso. Alcohol or WD-40
  2. If not resolved then check if the card is bent from the contact side.
  3. Try to format the card ( You will loose all data from your card )
I wish you will be able to solve your problem and this answer will be useful to others also.
Thank you for visiting and using FixYa
Dec 24, 2010 | Cameras
"Reinsert the memory stick"
I Have a similar problem, but fortunately I had a spare similar 8gb of new memory, when I tried this new memory and formatted it, everything has started working fine. It seems it is a memory problem. I would still like to know what had gone wrong with the original memory though! Hope this helps. Regards.
Nov 26, 2009 | Sony Cyber-shot DSC-T100 Digital Camera
Sony cyber shot DSC S930 "Reinsert Memory Stick"?
Your unit is still under manufacturer warranty. I would suggest to have it repaired through a authorized Sony repair center under the warranty CLICK HERE for support for your camera. Good Luck! : )
Nov 08, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I have a sony cybershot dsc-w80/w85/w90. I have
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
Oct 18, 2009 | Sony Cameras
No Pictures but full card
Sometimes when you edit pictures on your memory stick, it will transfer the files to a different folder. Then the card will seem blank to the camera. Format the memory card using the PC to clean it for good.
Nov 12, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
Memory stick
I think catcher-lock in memory slot is defective in your PC that's why memory card is stuck there. Use tweezers to pull it back as temporary solution and ask nearest Sony service center for replacement of defective part.
Aug 22, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Sony dsc w90
In the settings in the camera there should be a spot that you can change from internal memory to a memory card. Also you can remove the pictures off the camera from the internal memory by hooking your camera up to your computer via the USB cable that your camera came with.
Jul 28, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
