Question about HP Designjet 110plus nr InkJet Printer
How do I clean the HP designjet 110plus printhead
    Problem Solver:
  • 11 Answers
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Posted on Jun 20, 2009
  • koba Nov 05, 2013
    Use hot water to clean only clean the surface printhead.if System Maintenance Utility dont help you.
    Problem Solver:
  • 7 Answers
Go to the START and than choose Printer and faxes. You should see a screen listing the HP icon. Press your right mouse button and click on Properties. Go to Printing Preferences. A screen should appear showing SERVICE PRINTER. After this appears proceed through Each one of the option. You should have
ALIGN PRINT HEADS
CLEAN PRINT HEADS
After that your heads should be clean.
If they aren't please run through the Print head option again.
Hope this works
Posted on Mar 14, 2009
    Problem Solver:
  • 12 Answers
Use this link and chose your printer model and download all software :) best regards
http://h10088.www1.hp.com/cda/gap/display/main/gap_home.jsp?cp=1_4011_100&zn=gap
Posted on Jul 08, 2009
Dear sir,good day, during copying two blank(white) column detected on paper .can u help us ?
I do not know your product .any way this two blank lines means :-
1-the charge roller is not clean .
2- the corrona wire is dirty
3-first of all the glasses should be cleaned.
i hope thats help
Jan 13, 2017 | Office Equipment & Supplies
Load clattering on hp 4500 startup
if the boot process takes longer that normal, regularly goes back to reboot or you have other problems it could be a failing hard drive (Save all the files and folders to external hard drive and install a solid state hard drive --no spinning disc to fail)
if it is not that check the cooling fan operation for the power supply or chip-- about the only other things that have movement
Jan 12, 2017 | HP Office Equipment & Supplies
My Epson WF-3640 is printing with gaps in the text. How do I fix this issue?
Make sure you should remove shipping tape from the ink cartridge. These taps are used to protect printer during shipping but you have to remove it before starting printing. Beacuse these taps prevent the ink to entering in print head. If you will not found shipping tape in your printer then there is terr off strip, remove it. The tear off strip seals the the vent holes on the top of the cartridge to prevent it from drying out on the shelf or during shipping.
After ensuring that the shipping tape has been removed, run the printer's "Head Cleaning" utility to prime the cartridge, then print a test page.
See full detail at- http://guideusermanual.com/product-name-workforce-wf-3640-manual&po=152836&lang=English
Sep 18, 2014 | Epson WorkForce WF-3640 Wireless Color...
How to clean ink absorber for canon mp237
First of all open the ink cartridge of your printer.
When the ink cartridge would move all the way over, then disconnect the power cord of your printer.
Now pull the frame of rubber from the printer and remove ink pads.
To clean ink pads you may place them in a bowl having warm water and start rubbing and squeezing them to clean it from ink.
After removal of ink, keep the pads separate for dry.
When the pads get dry completely, place them back in rubber frame.
Reinstall the rubber frame in your printer.
For deep guide and support refer to-
Canon Pixma Mp237 Manual
Oct 07, 2013 | Canon PIXMA MP230 Multifunction color...
Okidata Microline 30 Turbo dot matrix
The problem your having is a spacer motor. It's located under the carriage that holds the ribbon/printhead. The part number is 56513701. Available at Seattle Platen - Dale 1800-221-2388.
Here's a free copy of the Okidata 320T service manual that will walk you through testing and verfying before ordering the replacement part.
If this helped you, please hit me up with a FIXYA. Thanks.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
Aug 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Problem installing drivers for HP 4355 printer in vista 32bit OS
Vista OEM Cd usually doesnt come with drivers.
Printer should have come with its own cd which contains both the software & drivers.
If it didn't come with any
You can try using windows update
or
downloading drivers from hp site
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1138373&lang=en
Feb 24, 2008 | Office Equipment & Supplies
Samsung kicked out hp 3in 1 printer already installed
Don't have your HP designated as the default printer (if possible)when you hook up the Samsung. When the Samsung is hooked up it sees the HP is the default printer. Well it can't have that, they discard the HP drivers. What does Samsung care about HP drivers theres only one printer port setup and thats the USB port you have them sharing. So yes you need to get a second cable. Tim
Jan 29, 2007 | Samsung SPP-2020 Thermal Photo Printer
HP Designjet 110plus nr InkJet Printer Logo
7,924 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
