Question about Panasonic DMR-EZ47V DVD Recorder/VCR
I have channel 70 on the dvd recorder. How do I
I have channel 70 on the dvd recorder. How do I get channel 3
  • jharanda Mar 06, 2009
    The recorder has a TV tuner, NTSC
    I am not trying to record channel 70, it just keeps showing up on the status pane.
    We have satellite, everything has to be recorded on channel 3.
    I can view previously recorded DVD's.
    I have never been able to record, even earlier when channel 3 was showing on the pane.
    I just think that I have to get this problem solved before I work on recording. I
    I have two other DVD recorders, and I had no trouble getting them set up. Earlier, I had a VCR on this recorder, but the Directv man came out to "upgrade" and left everything not working, wires hanging and loose. I could not get the VCR working again. I do not want him to come back here, so I bought a DVD/VCR Panasonic upconverting combo, added HD,
    but still cannot get it to work. I now record on one of the other recorders and my husband is not happy. (I am 83 years old, and admittedly do not think as fast or as well as I once did.)
  • Rob
    Rob May 11, 2010
    Does this DVD recorder have a TV tuner?
    Is the tuner NTSC or ATSC?
    Are you trying to record Channel 70?
    Are you trying to get the DVD recorder to 'output' on Channel 3?
    President:
  • 1,285 Answers
Ok..turn all the components involved on...(satellite,dvd,tv etc)....you need the dvd recorder remote...look for set up (if menu take u to setup)...we going to use the ><v^ to navigate to channel selection in set up.do we want to scan for more channels ? no auto ? no manual = yes now in order for this to never ever happen again we must delete all the channels from the dvd recorder memory leaving only CH 3 now can record ch 70 as long as the tv and dvd recorder is set to ch 3...........note just for future reference (most Disney and HBO products) are not going to be recordable...heads up
hope this is helpful
and I hope to be 83 keep on (34)
Posted on Jun 21, 2009
Hd recording
If the digital tuner can pick up the HD channels, then I don't see why it can't record them. However some TV channels have blocking on them to prevent recording. If it can't record a channel it will say so with a message, generally.
Jan 22, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
Timer recording will only record channel 3
Hello there,
This is most likely because the recorder is connected to a cable box. When setting the timer recording feature with a cable box as the source, you are not actually selecting the channel to record. You are selecting the recording source. The cable box sends all of the channels to the recorder using RF channel 3. In this case, the channel for recording will be whichever channel is selected on the cable box.
To help me give you a more definite answer, please can you answer the following quick questions:
1. Are you using a cable box?
2. If using a cable box, how is it connected to the recorder?
3. What is the model number of the GoVideo recorder, e.g. DVR4000?
Thanks,
BElectric
Feb 18, 2011 | GoVideo Go Video DVD/VCR Combo
Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Mar 02, 2009 | Toshiba DR410 DVD Recorder
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
How to record a running program from TV to DVD
RUN ANT,CABLE INTO DVD RECORDER THEN RUN A CABLE IN TO THE TV FROM THE OUTPUT OF THE DVD RECORDER YOU MUST HAVE TV ON CHANNEL THREE TO WATCH AND RECORD AT SAME TIME ,SET CHANNEL TO 3 ON DVD RECORDER OR INPUT SELECT CHANNEL YOU WANT TO RECORD AND PUSH RECORD WHEN READY
Dec 07, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Timer recording on GoVideo VR2940
First, you need to have the cable directly input into the recorder.
If you only plug the cable box into the machine, you get what is happening now.
After splitting the cable, one side into te box and the other into the recorder, run the channel seek part of the program and it will scan all the channels available on the cable and place them in memory.
Then plug the output of the cable box into the other input on the recorder, and you get yor pay channels and upper tiers.
Your recorder is now a switching unit as well
Woody Woodcasters@hotmail.com
Nov 19, 2007 | GoVideo VR2940 DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
91 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
