Question about GE Nautilus 24" Built-in Dishwasher
How to clean stainless steel
Brand new oven and dishwasher have stains after 1st use.
  • 170 Answers
You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard water...you may try a localized..(just for the DW and kitchen sink area) filtration system...to reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
Here are some issues and or cleaning techniques for stainless steel.
stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
2. Mild detergent, (dish washing liquid) and cloth.
For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
3. Glass cleaner for fingerprints.
Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
4. stainless steel Cleaner.
If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
Good Luck...........The Fang.
Posted on Apr 07, 2009
Please tell me how to get water stains off the front a stainless steel fridge. I have tried everything I can think of.
James, If really stubborn stains, you may have to use a chrome polish and buff. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cleaning Stainless Steel Appliances Cookware and More
Removing stains from stainless steel refrigerator
How to Clean Stainless Steel Appliances Easy Kitchen Cleaning Ideas That...
Coulter Cleanup Refrigerator Rejuvenation
Jun 11, 2016 | GE Profile PFS22 33" Artica French Door...
How to clean stubborn burned on stains in the stainless steel oven
You need to use ordinary soap as a lubricant and a fine steel wool to buff the steel surface. That will remove any built up surface debris completely but you may still have some discolouration of the metal remain.
An automotive polish designed for polishing stainless steel and aluminium (available from auto parts stores) might finish the job for you and remove much of any remaining staining but I would not use a chemical of that type on an inside surface that is used for cooking your food. (Same issue with those dreadful chemical and toxic oven cleaners).
Unfortunately, with use of the unit and heat , you will get some residual discolouration of the stainless steel.
Nov 11, 2015 | Stainless Kitchen Ranges
I love stainless steel appliances and have a lot of them at home. But, it is trouble cleaning them. They look really bad if they are not kept clean regularly. How can I get rid of the stains and marks on...
get a 'oxygen' based cleaner soak overnight.
normal cleaner works based on surfacetant. oxygen cleaners works by dissolving the stains.
of course, you can use some elbow grease and polish them.
Oct 16, 2013 | Ronco 'Showtime' Rotisserie and BBQ...
Top of dishwasher door is stained - how do I clean it?
you can buy a product by 3M which is designed to clean stainless steel appliances. It should remove the discoloration.
Link to cleaner:
Mar 07, 2012 | Dishwashers
Not cleaning very well
You can look at the powder that you are using and try some other brand. I am not sure what you are cleaning. are you cleaning stainless steel. or are you cleaning pot and pans?
Feb 20, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Hi ineed name of clean for stainless steel to make it shiney thanks
there are many differnt brands of stainless steel cleaner ZEP is a polular brand and used alot by most appliance companies this brand costs about 5 dollars american where as 3m makes there verison that not only cleans but also polishes there brand sells for about 9 dollars american never use soap and water on stainless it causes pits in the steel there are so many differnt brands though if you have a home depot near you visit one and check out the varieties preferbly everyone in my shop uses the 3m brings out a nice shine thats streak free if you have any further questions please message me back and please remember to rank how this opinion has helped so that i may further help others in similar situations Thanks again Rick
Jan 20, 2011 | Frigidaire Professional Series 24 in....
How to clean the oven
The inside of the oven can be cleaned with regular soap and water. Dawn works well on built up grease. if you have very stubborn stains easy off makes a low fume oven cleaner, but try hot soapy water first. the outside can be cleaned with any stainless steel cleaner or window cleaner.
Nov 20, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
The "stainless" steel is all rusted, streaked and stained. I have tried many products to clean it, but it remains unsightly and stained.
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish will remove the rust and pacify the surface. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Nov 01, 2009 | Maytag MDB9600A Jetclean II Built-in...
Kenmore Dishwasher - stops cleaning dishes - 2 techs just scratch their heads - any suggestions? water is hot, changed soap, still not even coffee stains inside cups are cleaned, let alone the rest.
ensure spray arm holes are not blocked, the water level is good, the spray of water is strong, it is heating and the tablet is entering the wash, not much else can cause a bad wash. note dishwasher may not always be able to get rid of some coffee stains.
Mar 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Stainless steel appliances ie. refrig, dishwasher & oven
a quality s/s cleaner and a clean cloth sould do the trick for most stains, WD-40 also works to remove the stains, works really well, also leaves afilm on the metal to prevent stains from adhering, just dont use paper towells, the tend to leave fibers behind. and also look closely at the s/s there is a GRAIN pattern in the metal just like wood would have a grain!! be sure to wipe in the direction with the grain not against.
Mar 19, 2008 | Refrigerators
GE Nautilus 24" Built-in Dishwasher Logo
328 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
