Question about Frigidaire GLTF1670A Front Load Washer
Rubber boot keeps getting holes in exact same spot then leaks
I;ve had the rubber boot on front load washer replaced 3 times and keeps getting holes in the exact same spot then will eventually leak water. Why is this happening
  • 283 Answers
Either its not installed properly or you have some sharp foreign object in the basket or tub
Posted on Mar 06, 2009
We have water leaking out of the front of our washer not from the door but from just below the door. Is all over the floor??
most likely you have a hole in the boot seal,the rubber piece in between the door and the tub,also open the door and wipe the bottom part of the door on the plastic window,i've found pieces of hair there and the water travels down the hair and leaks through the door.if that's clean you have a hole in the boot seal,open the door,spread the rubber boot open and with you fingers feel all around the rubber boot
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
I have LG WD -1050F Intellowasher 7kg front load washer, while operating time getting water leakage under front door. need solution.
The problem is due to the rubber boot is been torn that is causing you the leak. You have to check the rubber boot for leaks by removing the clamp assembly that secures the rubber boot to the outer lip of the door opening. Peel off the rubber boot then inspect it for any holes where it may be leaking. The rubber boot in your washer can be accessed only when you remove the front panel. This requires the removal first of the top panel then the console. Also check your inlet hoses on the outside of machine, also check the connections inside the panel in back.
Thank you !!
Jul 26, 2010 | LG Washing Machines
Leaking water from the front
Thank you !!
Jul 06, 2010 | LG WM-2277HW Front Load Washer
Leaking water from my lg front loader during washing cycle- wm2487hrm
Thank you !!
Jun 13, 2010 | LG WM-2277HW Front Load Washer
Whirlpool Front load washer - Water leaking
I would check to see if you have a hole or crack in the rubber boot inside the door. Open the door and seperate the fold in the rubber boot and check for a leak. If something sharp was left in someones pocket it will get stuck in this part of the bood.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smell
PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
Whirlpool bought MAYTAG about 3 year ago.
THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a Duet Whirlpool Front Load washer on the spin cycle it make a clanking sound and is now dripping waster from the bottom of machine.
your pump is going bad.the water is leaking from pump or rubber door boot that connects to tub and wher door shuts,check for tear in boot.
Mar 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leak at front of washer
You should have a drain at the bottom of the rubber boot inside the washer. There is a possibility the drain hose clamp came loose or the boot has a hole in it. If you take the front of the washer cabinet off, you should be able to see where the water is coming from. Take the two screws out of either side of the door opening, pull on both sides of the front panel at the same time, tilt downward, and the panel should come off.
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leaking front loader
the most likley place is the front rubber boot it can get a small hole in it and leak if the hole is not to large you can clean and dry it and reseal it with silicon rubber sealent
Dec 03, 2008 | Kenmore 44102 Front Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
81 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
