Question about Brother ML-300 Typewriter
The tape doesn't come up when I type. - Brother ML-300 Typewriter
THE TAPE DOE NOT COME UP WHEN i TYPE
Posted on Jun 16, 2009
Have unit hooked up, but cannot get the vhs casset tape e to remain in player, keeps ejecting.
Typically a VHS tape has a button on the underside that unlocks when pressed inside the VHS player. The wheels unlock and move the tape in the VHS. If this doesn’t happen, the tape will eject.
Oct 26, 2017 | Televison & Video
The lift-off tape is to low
1. Use the SPACEBAR or BACKSPACE to move the carrier to the center of the typewriter, then turn off the typewriter and unplug the unit from the AC outlet.
2. Open the Top Cover and remove the cassette ribbon, if installed.
3. Pull off both spools by holding the correction tape taut between the spools; bring the correction tape to a position parallel with the platen and lift up and out.
4. Pass the new tape through left guide, behind the ribbon guide and out through the right guide. The rough (sticky) side of the tape should face the platen.
5. Attach the feeder spool to the pin on the left.
6. Attach the take up spool to the pin on the right. Turn the take up spool counter-clockwise until a small amount of white tape has wound around it.
7. Replace the cassette ribbon and close the top cover, plug in the AC cord to the AC outlet, and turn on the typewriter.
May 20, 2013 | Brother GX-6750 Typewriter
My Philips MC145 tape deck doesn't work all of a sudden
I am guessing you took this apart? It sounds like the drive belt broke.
Feb 08, 2013 | Audio Players & Recorders
Screen is non-functional and irreparable
Turn off the power, unplug the battery and all cables.
Eject the installed battery if you have one.
This will protect you against electric shock.
Find the small, round rubber screw covers and pry them off.
This will expose the small screws holding the LCD screen frame in place.
Depending on your laptop, these covers might be made of some other type of material.
Remove the frame by gently prying.
Locate the LCD screen's cable and power supply cords. Unplug them and remove any tape holding the screen in place.
Check the identify of the manufacturer on the back or side of the screen.
It may be different than your computer's manufacturer.
Since these screens look so similar, make sure you order an LCD screen that matches your manufacturer's model number, or else the new screen will not fit.
Plug in the new LCD screen, replace any tape holding the screen in place and replace the frame.
Don't pinch any wires as you press the frame back into place.
Screw the frame down and switch on the power to see if it works.
If it does, go ahead and replace the screw covers.
If it doesn't, remove the battery, the screws and the frame.
Check your connections.
If it still doesn't work, call your parts supplier and ask for assistance in getting another replacement LCD screen.
hope this helps
Sep 17, 2012 | Computers & Internet
How do you hook up a sharp stereo cassette deck RT-W800
If that tape deck of yours has an audio line out jack (like the RCA red & white holes, usually located at the back), get an RCA plug to connect it to your stereo receiver's line in jack..... or
if that tape deck of yours doesn't have an audio line out jack but, instead, has phones (or headphones) jack (usually located at the side or front of the unit), then get a plug to connect it to your receiver's audio line in jack (RCA type, also coloured red & white).. Usually the plug is small so you may have to use an adapter for your tape deck's phones jack.
BOB (June 23rd '12 3:45am)
Apr 28, 2012 | Audio Players & Recorders
1989 buick riviera tape cassette doesn't work
sling it its had its day,most likely its a drive belt broke but its also possible that the mechanism that turn it on inside the tape player has got a plastic clip /switch broke off with age .
Sep 22, 2017 | 1989 Buick Riviera
I am trying to load a new roll of labeling tape into the Dymo Organizer 1610. But the tape doesn't advance properly into the front part of the machine that does the printing.
Before inserting the tape into the feed mechanism, bend the last 1/8 inch of the tape upward at a slight angle. This will insure that the tape feeds properly. I just learned this by trial and error.
Aug 03, 2011 | Office Equipment & Supplies
I recently brought out my vcr and am trying to clean it with Maxell VP-201 VCR pro head cleaner... but it doesn't say how to use it. Do you know where to apply the cleaner on the tape before I put it...
You can usually apply a couple of drops on the tape itself as it will not harm. The tape itself might have a hole located on the cassette itself close to the see through cover. We normal tell people to drop a couple of drops into the tape area
Jul 15, 2011 | Maxell VHS VCR Head Cleaner Wet Type 1...
My VHS tape will not eject from the VCR. I have a message flashing stating ERR. What can I do to eject the tape?
Hello
The mechanism of your VCR has jammed with video casette tape. If tape ribbon has got twisted around the drum motor head, or the belt that connected to eject [capstan] motor has elongated, this type of fault will occur. Either it will play, rewind, fast forward of eject. Just replace the belts first. In most VCRs the user can replace the belt from underside. Let the tape is there, if it is in, replace all the belts. Belts can be bought from most of the electronic spare part shops at your town. It will come as kit type, each model has its own belt kit, and you have to give them the exact model number of your VCR. Just open the cover of the VCR, and look for tape ribbon twist if any. If it is there, remove it carefully without making damage to any other internal parts, especially to video head. If necessary, cut the tape film. If tape twist is only the problem, it will be rectifed as this twist has been removed. If this also doesn't help you, replace all the belts. OK.
Jul 11, 2011 | GoVideo Go Video DVD/VCR Combo
Brother ML-300 Typewriter Logo
73 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
