Question about NorStar M7310 Corded Phone
Default volume HANDSET volume on a m7310?
All my users complain about low handset volume and when they change it using the volume bar while on a call, the next call goes back to default.
  • 2 more comments
  • dcoval Mar 09, 2009
    no I do not, but if you can help that would be great.
  • dcoval Mar 10, 2009
    Absoluting easy to understand, I will try later today, I am out of the office right now, thanks in advance.
  • formulacoop May 11, 2010
    This will have to be done on a T7316/M7324 or a phone with more than 8 programmable buttons.
    First press Feature ** 266344 you will see Password: Enter 266344 again. If you have a newer release Norstar you will see "Terminals&Sets" and you will have 3 arrows lit up on the display to the right. Whne you get further into programming you will see 4 arrows lit up. Here is what each button next to the arrow does
    top left (HEADER) takes you back to the header of the catagory
    bottom left(BACK) takes you back a steptop right
    top right(SHOW) lets you enter the catagory showing n the display
    bottom right(NEXT) lets you move forward a step
    after logging into programming and you see terminals&sets press the lower right(NEXT) until you see "System prgrming"
    Press the upper right(SHOW) and you will see "Change DNs"
    press lower right(NEXT) until you see "Featr settings"
    press the upper right(SHOW) and you will see "Backgrnd Music:"
    press the lower right(NEXT) until you see "Receiver volume.."
    press the upper right(SHOW) You will now have an option to "Change" When you press change you will see the display change from "use sys volume" to "use set volume"
    Once this is set for set volume the volume on the set should stay the same after you are off a call. The system by default has system volume set so the receiver volume will always go back to default settings
    Make sense?
    There is an option in programming under feature setting for reciever volume to "use system volume or use set volume" You will need to change this to "use set volume" Do you know how to enter system programming?
  • 43 Answers
Were you able to get this setup and working to your liking?
Posted on Mar 12, 2009
Volume control bar not working on meridian phone
If the volume bar does not adjust the ring you here when you do Feature * 80 and press up or down then send the phone in for repair.
Oct 18, 2012 | NorStar Meridian M7310 Phone
The volume on one of my Gigaset 8825 mobile handsets is very low. I have adjusted the handset volume to the max setting but still can barely hear the ringer. Is there another way to adjust the handset...
Hi, you can try to change the profile settings of the phone, because sometimes even if the volume is full but if the profile settings is on low, the sound will still be low.
Thank you for using Fixya.
Jul 15, 2011 | Computers & Internet
We have a meridian M7310 telephone system, and have just bought some headsets. Unfortunately we wish to use both headset, handset or speaker phone. Is this possible? Because at the moment we can only...
First of all, make sure you're plugged into the headset port of the telephone and not the handset port. Pressing the Handsfree button should change from handset to headset. You can't use the speaker phone with the headset plugged in.
May 13, 2011 | NorStar Meridian M7310 Phone
The volume on my handset is to low & the volume control does not change it!
To solve this problem you have to go into programming . Press feature ** 266344 then put in the passwored which is 23646 this gets you to terminals and sets put in your set number and step through for volume.
Oct 30, 2009 | NorStar Meridian M7310 Phone
Handset volume on Panasonic KX-TGA101S is too low
CLICK HERE for the user manual.
and HERE for the Base Unit
Pg 13 of the second manual designates how to adjust the handset volume.
The quick answer is to press TALK (or while talking to someone)...
Then, using the middle round button... press up or down to adjust the volume.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jun 03, 2009 | Panasonic KX-TGA101S Cordless Handset
M7310 phone not ringing audibally
If the internal calls dont ring, then there is something with the extension. When a call is ringing the phone, press the UP VOLUME. Chances are that someone accidentally turned the ringer all the way down.
Let me know if that doesnt work.
Nov 05, 2008 | NorStar Meridian M7310 Phone
Answering call
Feature ** 266344 password 266344 (assuming the default passwords are set)
A. Configuration
2. Line Access
Show set (enter the telephone extension set number that needs to be changed) ex 34
Then press enter 4 times until you see the 'Prime Line'
Press the change button to set the desired line that will activate when the handset is picked up.
(It will probably display 'None' at present before change)
Press enter and release.
Aug 19, 2008 | NorStar M7310 Corded Phone
Handset microphone volume low
Uniden 900MHz cordless phone can hear ringing. When I pick up the phone, volume is very low, hardly hear other side. Volume controls do nothing to raise it.
My email: xiejj01@yahoo.com.au
Nov 05, 2007 | Uniden Cordless Phone
Cannot here from the handset
Try changing the speaker in the handset. I did and it solved my low volume problem.
Oct 04, 2006 | Panasonic KX TC1740 Cordless Phone
NorStar M7310 Corded Phone Logo
2,251 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
