Question about Intel D102GGC2 Motherboard
My Intel D102GGC and Mercury 915GLV motherboard not wake up
Push electric switch,
SMPS working ok,
CPU fan working,
But power and HDD LED not indicating and BIOS wakeup beep not sounded. BIOS LED indication not appears on motherboard.
RAM, HDD, SMPS are ok
I check visa versa replace motherboard, but both motherboard generate same problem.
Static power problem or BIOS is erasing?
  • 447 Answers
Is this new ram or have you used it in this machine previously?
A couple of things can cause what you describe, one of them being the wrong voltage of ram. This page contains the list of memory that your system can use, check the part number on your current ram in google to find out what voltage it runs at (the recommended voltage for your board is 1.8v).
Other than that you may want to do a CMOS reset by changing the jumper block (should be described in your mobo manual), powering the machine on briefly, power it down (unplug) and return the jumper to it's original location. Now try to post the machine.
Posted on Mar 06, 2009
  • John Elliott
    John Elliott Mar 06, 2009
    One other thing - are you using onboard vga or an add-on card?
    If using an add-on card you may want to post the system without it so you can disable the onboard video in the BIOS and set the init display first to AGP (or whatever type of card you have) and than power down and install it.
Display off after some time
As you have checked all of the removable components. That only leaves one bit left. The motherboard. Check the capacitors around the CPU socket and the Power connector. There is a common problem with Socket 775 CPU it is that the contacts on the CPU socket can be badly connected even when the CPU is fitted and locked in.
Jul 26, 2013 | Intel Essential DG41WV Desktop Motherboard...
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
Mother board fault
NO problem about..... the mb..
its ok.. The problem may be with SMPS or motherboard...
Contact the from where you buyed your PC..
May 30, 2010 | Mercury P4VM800M7 Motherboard
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
Cpu not starting up....power 2 cpu from smps is ok..
hi most of motherboard power on pin is 6 and 8 just short these two pins once if mothernoard starts it;s giving display else check ram or smps otherwise motherboard faulty.
Oct 03, 2008 | Intel Motherboard
HI - benimur
  • fans, OK;
  • PSU, new;
  • HDD, disconnected;
  • ad no part/component heating up (barely touchable).
that leaves us only three possibilities:
  • motherboard (most likely);
  • memory (likely);
  • CPU (least likely)
Aug 18, 2008 | Intel Motherboard
CPU is not getting started
In SMPS 20 pin Connector please short the green and black wire with a twisterand on the smps. if the fan is rotating then the smps is ok
Jun 19, 2008 | Intel D845GVSR Motherboard
Intel D850MV motherboard
If you hear no beeps and the led lights, and the fans stay on after striping all the components from the motherboard except for the cpu, and power supply, you have either fried your motherboard or your cpu. Its impossible to tell without more testing. I'm sorry but you either need someone to test it or you can buy a new computer (thats what I did). For about USD $300-$400 you can get a brand new computer with 500mbs of ram, 120gb hard drive and a 3 ghz cpu. If you look around you can get an even better deal.
Aug 15, 2007 | Intel D850MV Motherboard
Intel D102GGC2 Motherboard Logo
496 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
