Question about Dell Dimension 4600 PC Desktop
I bought a connector that you would use for an ipod but, I still have no sound. On the back of my Vizio TV...where the RGB cable is hooked up, there is a small headphone size jack there. Is that the one I'm supposed to be using to play sounds through my computer?
  • pdeninno1 Mar 09, 2009
    Thank you!!! I did have the right connector, my problem was the System mixer... Thanks again for your help.
  • 463 Answers
Clarifying...
You are trying to play audio from the TV through your computer?
You need an adapter cable that has an 1/8" stereo phone plug on one end, and two RCA male jacks on the other end.
The RCA connectors are to be plugged into your RV using the AUDIO OUT jacks (usually red/white) and the small plug goes into the auxiliary or line in jack on the back of your computer.
Then, Double-Click on the volume icon in the system tray (this should bring up the system mixer), unmute the line in sound if it is not already and run the "slider" control for that input up about half way.
then, Tune the TV to whatever channel or input you wish and adjust the volume level on your computer to a comfortable listening level.
Rob
ps. Some TVs don't use fixed level audio outputs, and the volume will vary as you run the volume up/down on the TV, too...
Posted on Mar 06, 2009
We are trying to hook up a VIZIO sound bar model#S3820w-Co to our Vizio TV we also have Directv and a dvd player hook to this tv which wire do we hook from sound bar to Tv
If the TV and sound bar have an optical connector, then get the optical cable to connect the two. If not then use the audio out jacks on the TV and don't forget to change the audio set up to switch the sound to the sound bar.
Oct 29, 2014 | Televison & Video
Sd 4200
Make sure your DVD player has HDMI or Component RGB output,you will also need RGB component cables or HDMI cables to connect the DVD player to your Vizio,once you have attached one of the above cables you will need to press the input button on your TV'S remote to select either HDMI or Component.
Jun 07, 2012 | RJ Tech 4200 DVD Player
I have a Vizio 37" TV (VW37L HDTV 10A) bought in
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ ///
Sep 03, 2017 | Vizio VW37L 37 in. LCD TV
I hooked up my vizio 22" tv up to my laptop
Check the tuner i/o board connector there might be a loose connection from the soccket.
I/O board means input output board, this is where the antenna and audio video input are pack in.It is just inserted at the socket..check whethere the connectors are lock properly
Jan 30, 2011 | Vizio VA220E LCD TV
How to hook up TV with set top Cable box
If you have a new HD cable box then I would use the RGB cables. It is a 5 cable cord with color codes of RED-GREEN-BLUE and a Red/White for audio. They will go from the output of the cable box to COMPONENT INPUT on the back of the set along with the audio in. This will give you the best possible picture and sound.
Nov 26, 2010 | Vizio VA26L 26 in. LCD HDTV
TV displays RGB code and then displays, no signal and then shuts off. What does the RGB code mean?
It means the source is not set correctly. Switch the source to input 0 (cable or antenna depending on your particular set up).
http://www.vizio.com/l32hdtv10a.html#support
Will lead you to the manual and quick start information if you need more specific instruction.
Joe
Jan 03, 2010 | Vizio L32 32 in. LCD HDTV
Extended my monitor to a Vizio 37" LCD TV Echoed Sound
You have an HDMI connection on a Thinkpad T20???
Per definition, HDMI is supposed to send video and audio data from the TV to the PC -so, yes, it should work.
I say "should", because I tried to hook up my PC that way and I went back to a VGA connection (and sent the sound to an old stereo), because the resolution was awful.
I rather think that the audio cable is the culprit here - if the connectors are not fitting perfectly, they can create a lot of distortion.
Also check your audio settings on the PC (updated driver, settings not on maximum volume, etc.)
If you want to try HDMI, there is no need to get the ultra expensive "Monster" cable. Look here for an example.
Feb 24, 2009 | IBM ThinkPad T20 2647 Notebook
Can't play ipod through TV
The new iPods don't work like the previous ones. The cable you need for yours most likely uses the dock connector on the bottom. I ran into this as well. Why do they do this? Oh, yeah... money. ;)
Aug 21, 2008 | Belkin PureAV iPod™ Optical Cable...
No sound with new Vizio 22" LCD TV being used as monitor
you have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Dell Dimension 4600 PC Desktop Logo
130 people viewed this question
Alun Cox
