Question about Bogen Communication Bogen Manfrotto Tripod 351MVB2 Pro Video Aluminum W/503 Fluid Head
One leg slipping
Hi, the lower leg of my manfrotto tripod isn't holding. the model is 351mvb2...how do i tighten it?
3 Suggested Answers
morgan747
  • 9 Answers
SOURCE: Leg clamp tightening adjustment on a 055 tripod
There should be a nut on the other side of the housing of the tightening lever that you can tighten. Turn the lever to unlock the leg then start with 1/8 th turns of the nut to tighten, then turn the lever to lock the leg. Do this until you get the desired locking.
Posted on Mar 20, 2009
  • 175 Answers
SOURCE: I have a Manfrotto 058 tripod. One leg wont hold
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Posted on Nov 04, 2010
Leg stuck on Manfrotto 732CY tripod
Other than the leg locks themselves, sometimes Manfrotto expands the last portion of the leg tube that slides into the leg tube above it. If you need some spare parts you can find them here.
www.bogentripodparts.com
bogen and manfrotto are the same company
Nov 07, 2012 | Manfrotto Bogen 732CY M-Y Carbon Fiber...
How do I release a Manfrotto 501HDV head from a tripod
Tip the tripod upside down, on the bottom plate where the head attaches there are 3 screws... they need to be loosened, and then the head will spin off.
Oct 27, 2012 | Manfrotto 503HDV Head and 351MVB2 Tripod...
A couple of the lever locks on my Manfrotto 055XB tripod are no longer sufficiently locking the legs so they slip. How do I tighten them?
Use an 8mm, I believe, socket and tighten 1/4 turn the nuts on the lower half of the leg lock. For instance, the top leg lock is connected to the top and middle leg. Tighten the lower 2 nuts (located on the middle leg half of the lock) 1/5 turn. If that does not do it, tighten 1/4 turn again. Be sure not to over-tighten.
Aug 10, 2010 | Manfrotto 055XB Tripod
Broken leg clip on Manfrotto Modo 785B tripod the head is non-removable on this model and I don't want to have to replace whole tripod so is there somewhere I can buy a new leg clip or get it...
Yes you can. But I saw that your Manfrotto is possible to buy for 50 Euro.
Anyway the part you need is the full leg called CODE:
R785,203B
you can see the datasheet on the spare part site of Manfrotto:
http://www.manfrotto.com/webdav/site/manfrotto/shared/manfrotto_nord/pdf/7/785B_20070503.pdf
Regards
PDG
May 09, 2010 | Photography
Missing Tripod parts
Without knowing the brand of tripod i cannot help. There are some brands of tripods that are made for the retailer and the name is licensed, so the name brand does not support or stock repair parts. Especially if the tripod is an inexpensive one. Because of the model and make of you tripod, I would recommend you throw it out and buy another one. In my opinion Slik and Manfrotto are two very good ones. Slik for the lesser expensive and Manfrotto for the more durable, expensive, parts are almost always available unless is it really old tripod. Find some Manfrotto tripods at: www.BogenTripodParts.com
Feb 12, 2010 | Photography
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
My fluid video tripod head is stuck to the tripod. help! note: i have the manfrotto 503hdv head, and the legs are actually manfrotto 055CXPRO3 i have tried tightening the head controls. i have...
Make sure you are loosening the 3 grub screws under the tripod head to release it from the tripod center column. there are the 3 slotted screw heads under the grey part of the tripod head. Make sure you back them all the way out before you start to loosen the head.
Jan 28, 2010 | Manfrotto 503HDV Head and 351MVB2 Tripod...
I have a nice manfrotto tripod and one of the snaps on one of the legs no longer works, so the tripod now slouches on one leg. Is it worthwhile to repair it, or do I just need to buy a new one? I paid...
If the leg lock is still there in one piece, should be no issue. If you notice, the leg lock covers bothe an upper part of the leg and a smaller diameter lower part. Take a socket (8mm if I remember corectly) and barley tighten the nits on the bottom half of the locfk. Loosen and tighten nuts until rasing and lowering leg is no issue.
Jan 10, 2010 | Photography
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
I need a lower leg clamp for my 190xb manfrotto tripod.
You can order the lower leg clamp as a part from http://bogentripodparts.com/parts/190XDB.htm
Follow the link and check for your part number.
Hope this helps,
Andrew
Oct 05, 2009 | Manfrotto 190XB Tripod
Photography Logo
Top Bogen Communication Photography Experts
pontelemon
pontelemon
Tony
Are you a Bogen Communication Photography Expert? Answer questions, earn points and help others
