I am jeremiah ondande. Bought a PIXMA830 a while ago works on printer side, but now neither the scanner nor the fax nor the copier works! Which also means that the light under the glass does not come on either! What do you think is the problem?
  • 547 Answers
Not hooked up right or blown circet or fuse
Posted on Mar 06, 2009
CARRIAGE ERROR It cant send fax and copy
I AM A AMATOR REPAIRMAN OF COMPUTER HARDWARE. A FEW DAYS AGO I SOLVED THIS PROBLEM ON PRINTER PANASONIC KX-FLB802 BY SERVICING ITS SCANNER. OPEN SCANNER PART AND PUT SILICON OIL ON WITHE MOVING PART OF IT.
TOP AND END OF TWO SIDES ARE TWO WITHE PLASTIC PARTS. IT SOLVED BY OILING. THE END.
SORRY BECAUSE BAD ENGLISH.
Dec 20, 2010 | Panasonic KX-FLB801 All-In-One Laser...
My Brother MFC490CW Fax M/c will only send one fax then reverts to scanner
A DEPENDABLE MACHINE BUT LACKS PRINTING QUALITY! Date of Review: Jan 14, 2009. The Bottom Line: Love the fax...not too impressed with printing quality or ink prices. Review: I bought my Brother Multi-Function Center 440CN a couple of years ago. .... Brother MFC-490cw Color... Brother MFC-440CN All-In-One. ...
www.shopping.com
Dec 03, 2009 | Office Equipment & Supplies
My problem is with the HP PSC 950 series printer, fax, scanner, copier. The fax and copier work sporatically, sometimes producing a copy or fax and most times not. Please help
faxing,scanning and copying use the same mechanism,thts the scanner,if its doing it intermittently you can try a reset on the printer.see if tht works.
Jun 24, 2009 | HP PSC 950 All-In-One InkJet Printer
Lexmark series x2350 all in one scanner does not work.
Is the scanner driver installed ?. You can check this by unplugging the USB cable from the back of the printer and connecting it again. If you get any Plug and Play prompts on the computer, install the driver by pointing it to the correct scan driver location.
May 27, 2009 | Lexmark X2350 All-In-One InkJet Printer
Fax Machine not recieving faxes
Check your fax settings again follow the instructions on Printer menu and set the FAX rings to 5 or 10 and also check the paper settings and papers in tray. If not worked tell me the model of your fax machine.
Mar 14, 2009 | Brother MFC-7820N All-In-One Laser Printer
I have had a lexmark printer/fax/scanner for about 3 years. I have never used the fax part. The printer works perfectly well but about a month ago the scanner stopped working. Can you please help. I do not...
Possible, your printer has worked out whole its resource. Even though his(its) repair technically possible, he will be expensive. Your warranty service was expiredabout 3 years. Think about buying new. Good luck.
I have bought itself from Epson.
Mar 06, 2009 | Lexmark X7170 All-In-One InkJet Printer
HP 5510 Scanner/Copier/Fax Stuck
I had the same problems some months ago. I only solved it when I deleted the printer settings from my computer and reinstalled the software, making sure that I installed all the components from the CD. Also make sure that the printer is on fax default setting when you are using it as fax. You can check this by going to My Computer then Control Panel, then choose Printers and Other Hardware then choose Printers and Faxes. You can then set as default hp Officejet 5500 series fax. Hope these suggestions help.
Jan 08, 2009 | HP Officejet 5510 All-In-One Thermal...
Scanner Directions
Scanner utility is pretty much come with the software. You can input the paper like you input for fax, either on the top scanner or the scanner itself and then just press scan on your printer. It will automatically scan to your computer. Please make sure your computer is connected to the printer.
Thanks
Aug 12, 2008 | HP LaserJet 3380 All-In-One Printer
Scanner doe not work,fax and print are ok
first re-install product driver properly then try.
Jun 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon Pixma830 all-in-one beeps when I connect it to my phone line
When you attach the phone lines, the line coming from the wall must be put in the "L" (line) jack on the machine. The extension phone can be plugged into the other jack. If you have the line coming from the wall to your phone first, and then the extension line coming to the machine, you will get the beeping. You must have two lines plugged into the machine.
Jan 11, 2008 | Canon PIXMA MP830 All-In-One InkJet...
19 people viewed this question
jasbo
jasbo
