Question about Dell Latitude C610 Notebook
My laptop will not turn on. i push the power button and the lights flash on like it is getting ready to work and then they just go off.
  • Anonymous Mar 10, 2009
    same the laptop want turn on the lights just flash an it goes back black
    Sergeant:
    Champion:
  • 224 Answers
This sounds like a hardware problem, unless your battery is dead. try removing the battery out, connect the adapter and turn on?
Posted on Mar 06, 2009
A problem like this is often a power problem. If your battery is almost dead and you don't have a good power connection, the laptop might attempt to come on but then quickly shut down again. You should check all of the power cord connections. Is it connected well in the back of the laptop and at the wall? Some power cords also come apart in the middle, so you should check there, too. Also, are you actually plugged in to a live outlet? If it is a surge protector, the power switch might be off.
Hopefully your problem is this simple. If not, you probably have some sort of hardware failure and will need to have a shop diagnose the problem.
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    Toshiba satellite 1005 s157 laptop powers on and then turns off
    it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
    success
    Jun 18, 2012 | Toshiba Satellite Computers & Internet
    The wireless light on the router is not lite up and won't connect to my wreless printer, in witch it use to work. i have tried to reset the router and unplug from the moderm, nothing is working. please...
    Turn everything off, modem, router and computer.
    Turn on the modem first and wait for a solid data/connect light.
    Turn on the router, give it two minutes.
    Still if problem presists you need to reset the router ..
    How to reset::
    Push and release the “Reset” button.
    The lights on the Router will momentarily flash.
    The “Power/Ready” light will begin to blink. When the “Power/Ready” light becomes solid again, the reset is complete
    Jun 03, 2010 | Belkin F5D8236-4 Router
    My Belink (F5D8236-4) Router stopped working. The modem light blinks orange. When connecting the modem directly to the PC the internet works. How do I resolve tis issue?
    It shows your router is not configured properly
    How to reset::
    May 15, 2010 | Belkin F5D8236-4 Router
    The red standby light flashes and when the power button is pushed the green light comes on with a clicking soung then it turns back off and the red standby light starts flashing again
    One of the boards (module) has a short on it, and or the power supply itself is failing.
    The service center will find the fault using the process if elimination. They will replace the bad boards or modules as required to get the set working again.
    Jerry G.
    Dec 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
    Compaq laptop will not power up
    try taking the battery out, make sure the ac adaptor is not connected, hold down the power button for 60 secs and then put the battery back in and try turning it on.
    Sep 14, 2009 | HP Pavilion dv6000z Notebook
    Power button malfunction
    Sounds like a faulty power supply. Consult warranty guide if its still under warranty, if not, you really need to consider calling a repair technician
    Feb 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
    Cant get the BELKIN to work
    From the manual:
    Resetting the Router
    Push and release the “Reset” button. The lights on the
    Router will momentarily flash. The Power/Ready light will
    begin to blink. When the Power/Ready light becomes solid
    again, the reset is complete.
    b. Restoring the Factory Defaults
    Press and hold the “Reset” button for at least 10 seconds,
    then release it. The lights on the Router will momentarily
    flash. The Power/Ready light will begin to blink. When the
    Power/Ready light becomes solid again, the restore
    is complete.
    Feb 12, 2009 | Belkin (F5D5231-4) Router
    Wont start
    My solution (works every time) is to pull out the AC cord from back of computer. Then .. release the battery for several seconds only. Push battery IN again. THEN (presto) Push power-up button. It starts normally, every time. Then when you're ready just push the AC lead back in after it's started. Don't ask me why it works. It just does. It's like it needs the battery power to be isolated briefly and then re-applied. It works. I never bothered with warranty work. It's like an extra security feature. When it's off AC for a period -> that's the reliable starting method. Also, computer may be in hibernation mode. Hold the power down until you see a boot up screen (i f you can get to it)
    Sep 01, 2007 | HP Presario M2000 Notebook
    Dell Latitude C610 Notebook Logo
    64 people viewed this question
    Brian Sullivan
    Brian Sullivan
    mukhtar21 shaikh
    mukhtar21 shaikh
