Question about HP PhotoSmart C4280 Laser Printer
Error while printing(and doesn't print) from the web pages
It prints ok not from the web but does 'not make the print connection with web pages ( documents etc)
    Sergeant:
  • 300 Answers
You will have to copy the web pages and paste it on the microsoft word folder and then give the printout it will print.that is the system.
Posted on Mar 06, 2009
The printer won't print... it demands I try a test page... I print the test page and it STILL won't print. My ink cartridge levels are fine!
ok first thing to check is the connection. either network or usb, Go to start on your computer and bring up devices/printers and faxes. look for your copier. right click and select printer properties it will be below preferences. you should get a page come up. first option is general, select the PORTS option and check the ticked address, either the ip address or usb. if it on parralell port this can cause errors. it might have selected this if you have a usb port try swapping the usb selection. If on network cable check the IP address is correct. You can check the ip by typing it into your web browser and the web page for the copier should come up if connection good. It sounds like the connection type may be wrong if its saying off line. Good luck,hope it helps
Oct 17, 2015 | Canon PIXMA iP3500 Printer
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
I've got a Lexmark T520 and it's not printing anything from photoshop - it says 'flushing buffer' and then just doesn't print. It will print from other sources i.e. web pages...
to large a data being sent for memory on printer photoshop will be hungry data and its has to small a memory to cope ok for normal printing but not this type of work
Aug 14, 2011 | Lexmark T644 Laser Printer
How to print a page from a website
Please follow the steps to Print a web page using the Internet Explorer or Mozilla web browser.
>Please click on File, Print or press Ctrl+P key and then select the Printer( HP Officejet 5610), select the page range and click OK to print the web page contents.
>You can also preview the web page you're trying to print and then print it (File-->Print Preview).
Good Luck!!!
Jul 02, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer will not print the content from a website. The only thing that prints is the footer. Even when the Print preview shows all of the content on the web page, it will not print on the paper.
Some web pages are made up of two or more frames. If you use the Print button on the toolbar, only the active frame will be printed. To print the web page at it appears on the screen or to print only one frame use the Print dialog window to select what you want to print:
1.To print the web page including all the frames, in your web browser, click the File menu and select Print. In the Print Frames section, select the radio button next to As laid out on screen and click OK.
2. To print one frame, left click once on the frame you wish to print to select it. in the Print Frames section, select Only the selected frame and click OK.
Alternate method: Right click on the frame you want to print, choose Open Frame In New Window, then just print it out from the new window that opens as you would a non-frame web page.
Note: In Windows Internet Explorer version 5 or above, framed Web pages are printed with each frame coming out on a separate page by default.
Jun 22, 2010 | HP Photosmart 2610 All-In-One InkJet...
Unable to print error
In Internet Explorer, manually print each link on the Web page. To do this, follow these steps:
  1. Right-click a link, and then click Print Target.
  2. Click OK.
  3. Repeat steps 1-2 for each additional link you want to print.
Nov 22, 2009 | Brother MFC-9420CN All-In-One Laser...
Prints only on left side of page.
In printing web pages and email please try to check also the print setting before you print the page cause word document files and web pages are not the same in there printing setting. Web pages and emails has different setting so my recommendation is that when you print email and webpages next time then please check the printer settings then modify it the same settings as you wish or as your word document's output.
Thanks
Aug 18, 2009 | Epson STYLUS R230 InkJet Photo Printer
TrendNet PrintServer TE100-P1P does not print
I get the same error connecting to an OfficeJet K60. Have been successful with my Macs, but not with XP.
Jul 08, 2009 | Parallel TRENDnet TE100-P1P 1 Port Print...
Hp3650 won't print from web page (error #20)-prints non web sourc
Hi scebulko:
Error code #20 means that the printer has received maore data from the computer than fits in availiable memory.to avoid this in the future you need to upgrade your memory.
pdouglasss
Dec 10, 2008 | HP LaserJet 3600n Printer
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP PhotoSmart C4280 Laser Printer Logo
93 people viewed this question
Seeker5211
Seeker5211
