the monitour will go from green light to orange after sitting for about 10 or 15 min. you move the mouse and it does not go from orange to green. you have to restart the computer.
Lower down the computer resolution and frequency rate from Video setting>>Advanced in control panel (personalize on Vista) replace the video cable.
If that does not help then the monitor is defective.
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
The internal circuits are jammed because of electrostatic charges
accumulating on capacitors, or because of a wrong voltage read by the
main chip on your monitor controller board. this started the protection
circuit.
2 The protection circuit detected a wrong voltage or a
broken contact, identified an internal fault and kicked in , starting
the flashing light.
If you are in situation one, then the
monitor will reset just unplugging power cord for one or two hours,
sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common
faults that can occurr suddenly are a blown capacitor on power board,
the inverter board powering up backlight lamp has blown, or a fault on
main lcd controller board.
check also the video cable, if the cable
is shorting, or the connector is bad, you can get same flashing state
because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact manufacturer to find out a service point.
If you want to repair at your own expenses, just locate any good qualified repairer.
I have this monitor and just bought a new computer. When the computer boots up and gets past the...
(More)
I have this monitor and just bought a new computer. When the computer boots up and gets past the "windows" graphic monitor goes black. It worked fine with my old computer and my new computer works with an old crt moniter. I tried setting the res to 800x600 and it still won't work. right before it goes blank I get a box that says "oversize command mode 1280x1024". Any ideas?
