Question about Zebra Eltron LP 2824 Thermal Printer
Kyocera fs-c 5030 has a terrible grinding noise in the front. could it possibly be the drum unit(black)
  • 2,120 Answers
Take all the toner carts out and push down on the units below the toner carts. Make sure the waste bottle is pushed in firmly. More than likely, the waste system is clogged up because the waste bottle was loaded crooked.
Posted on Mar 07, 2009
Kyocera FS-3920DN call service 2000:0011742
The call service 2000 is about the main motor. Pull the Developer Unit and then the drum unit out of the printer and check if the gears on both units are moving freely. Then turn the printer on without the 2 units and see if the motor is functioning. If your the motor moving then the message displays on printer will be 7410 (because you have the drum unit outside). There is a possibility that the transfer roller is damaged.
Mar 26, 2014 | Kyocera Fs-3920dn Laser Printer
Vertical black line at the bottom of my printout
open copier front cover and remove developer unit, after that remove the drum unit ,pullon green handles on each side, the drum unit has a green cleaning lever on it ,make sure it is all the way to right side,
arrows on lever and frame of drum should meet,if this is out of position a line will appear.
Mar 20, 2014 | Kyocera FS-1135MFP
Seven black spots are appearing (pea size) from top to bottom in a line? How to get rid of them? Thanks.
Hello, The Kyocera FS-4000 have a separate Drum Unit and Developer unit installed.
The Developer delivers the toner to the drum unit, either could cause the issue you are describing. The Fuser in the back is also a possibility, however remote for this discussion. The most likely component failing is the developer unit. The developer is accessed by flipping the top cover and withdrawing the developer out. Look at the developer roller for a smudge or smear, you may be able to smooth out any smudges with a piece of paper, do NOT use your hands or any liquid of any kind. The drum unit slides out the left side of the printer VIA the access panel. The cost of these components can be quite a bit. If you have any spare I would install them one at a time and see if you can determine which is causing the problem.
302F993011 DK-310 (Drum Unit)
302F993030 DV-322U (Developer Unit)
302F993072 FK-320U (Fuser Unit)
Jan 16, 2011 | Kyocera FS-4000DN Laser Printer
Error llama 7410 0013444 impresora kyocera ecosys fs-4000dn
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
- Defective engine PWB.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Aug 04, 2010 | Kyocera FS-4000DN Laser Printer
Change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Aug 27, 2009 | Kyocera FS-3900DN Laser Printer
CALL SERVICE 7410:0002988
Turn printer off
open left door
push in DRUM unit
turn back on.
Feb 10, 2009 | Kyocera FS-2000D Laser Printer
Kyocera FS 1010 printer. Not printing even with new cartridge
may be moisture.just switch the dehumidifier on for some tine.
Jan 18, 2009 | Kyocera Mita FS-1020D Laser Printer
Kyocera FS-C5016N
when you open the left cover you will see some green plastic things. If you pull these towards the left they will clean print heads and charge coronas.
If this does not fix the problem the you will have to remove the dev and drum units from the machine.
The print head sits on top of the drum unit and can be levered off with the three tabs gently lifted.
the entire print head can be remove once the black cover has been unhitched from the sides.
The print heads are not screwed in and what ever you do DO NOT TOUCH THE SCREWS on the print heads as they are only for density adjustment
Aug 08, 2008 | Kyocera Mita FS-C5016N Printer
Zebra Eltron LP 2824 Thermal Printer Logo
240 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
